04-23-2019, 11:27 PM | #1 |
Newbie Join Date: Mar 2019 Location: Roseville
| JustinL Bomber build
Hey everyone so this was m first crawler build and was really fun build. Not sure where I am going with it upgrade wise but I will update this build thread when I do. Sent from my iPhone using Tapatalk |
05-03-2019, 05:08 PM | #2 |
| Re: JustinL Bomber build
Was thinking about getting a 2 speed out of the three that I have able to find (axial,ssd, and hr) what would be the better choice? Sent from my iPhone using Tapatalk |
05-04-2019, 03:11 AM | #3 |
Newbie Join Date: Apr 2019 Location: Uk
Very nice bomber mate.Unfortunatley I don't don't have a clue about the 2 speed tho.
05-04-2019, 05:58 AM | #4 |
Newbie Join Date: Mar 2019 Location: Kamiah
There is a lot of threads on the rccrcawler about using a brushless motor instead of the 2 speed.
05-04-2019, 06:33 AM | #5 |
Newbie Join Date: Apr 2019 Location: Edmonton
Rc4wd two speed Sent from my iPhone using Tapatalk |
05-04-2019, 07:02 AM | #6 |
| Re: JustinL Bomber build |
05-04-2019, 06:32 PM | #7 |
Quarry Creeper Join Date: Jul 2017 Location: Sweden
I have the Axial 2-speed in both my Yeti and my Bomber, and am really happy about it. As far as comparisons go, I can't do any though. If I didn't get the Axial one, I would get the SSD, simply because they were the first to do it and some of the other brands are basically just a rip off of SSD:s design. If you get SSD, you might want to get the lever set from Axial. It's not necessary, but might make it a bit easier to set it up. Couple the 2-speed with a Mamba X, so that you have 100% drag brake and instant reverse in gear 1 and less drag brake (30-50% or whatever is your preference) in gear 2, and you have a very flexible rig. You will crawl like a champ, and when you go into 2nd gear and race off, you will not risk a front flip as soon as you let go of the throttle. A good sensored motor does not give you that flexibility. |
05-08-2019, 10:18 PM | #8 |
Newbie Join Date: Aug 2011 Location: Helena
05-09-2019, 12:06 AM | #9 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
I'm using SSD 2 speed with a ROC412 3100kv 3s.
05-09-2019, 12:36 AM | #10 |
Does that seem to work well?
05-09-2019, 07:53 AM | #11 |
I went ahead and got the Hot Racing two speed installed a couple days ago and I couldn’t be happier. Right now my I’m running a stock spec Hobbywing xr10 and Eco Power slingshot 17.5 that I pulled out of my tlr 22 just get the bomber running. Next up is a better esc and motor. I’m wanting something with a little more speed. Sent from my iPhone using Tapatalk |
05-09-2019, 10:22 AM | #12 |
Welcome to the site! Sweet paint job! The best ESC for the Bomber is the Castle Mamba X. For motors I like Tekin ROC412 or Holmes Puller Pro. That's a high end setup. |
05-10-2019, 09:23 PM | #13 |
Quarry Creeper Join Date: Nov 2009 Location: Hickory,NC
Mamba X and HH Puller Pro 3500kv on 3s in my Bomber.
05-12-2019, 09:17 AM | #14 |
05-27-2019, 07:16 PM | #15 |
Over the weekend I decided to paint the bead lock rings and added a cheapo led light bar. Sent from my iPhone using Tapatalk |
08-18-2019, 09:14 PM | #16 |
Had some stuff laying around from my FPV micro quads and an idea popped in my head. So I took one of the extra helmets from the kit and now some FPV crawling. Sent from my iPhone using Tapatalk |
08-19-2019, 06:40 AM | #17 |
RCC Addict Join Date: Jun 2017 Location: Canada
That's actually pretty nice. I have the same FPV AIO (Eachine TX03) on my drone and my yeti jr. Didn't know they fit inside the bomber helmets! Their field of view is limited, you might not see much being inside the truck but I can't wait to see footage! Sent from my Pixel 2 XL using Tapatalk |
08-19-2019, 04:41 PM | #18 |
Definitely not the best but could still be fun. I think a camera with the vtx separate would be better with clearance of the roof. Sent from my iPhone using Tapatalk |
08-19-2019, 09:31 PM | #19 |
It will be very good on flat ground but crawling you won't see anything Sent from my Pixel 2 XL using Tapatalk |
08-25-2019, 12:41 PM | #20 |
Newbie Join Date: Nov 2013 Location: Long Island
Nice Job. I run a Mamba X and ROC412HD 3100KV. Don't see a need for the 2 speed lol.
JustinL Bomber build - Similar Threads | ||||
My Bomber Build | angrchair | Axial RR10 Bomber | 182 | 02-21-2021 05:10 PM |
Bomber build help | 541MM | Axial RR10 Bomber | 7 | 05-08-2019 01:53 AM |
Need Help with Bomber Build | Digs1111 | Newbie General | 7 | 09-03-2017 01:40 PM |
Bomber Build | bignheavy1007 | Axial RR10 Bomber | 4 | 09-28-2016 01:18 PM |
My Bomber build | bredmx | Axial RR10 Bomber | 8 | 12-28-2015 11:51 AM |
