Let's see your Bomber body We all have one of these, right? https://live.staticflickr.com/65535/...8416cb91_c.jpg20190925_075955 by MAC FAB, on Flickr How and/or what have you done to to cover it up? |
Re: Let's see your Bomber body barndog custom panels with a custom wrap made by me.https://uploads.tapatalk-cdn.com/201...4f319f45b8.jpghttps://uploads.tapatalk-cdn.com/201...153a430cf4.jpg Sent from my SM-G965U using Tapatalk |
Re: Let's see your Bomber body #Fastpanels Too bad Wayne stopped making them...[emoji26]https://uploads.tapatalk-cdn.com/201...ebd7a2d835.jpghttps://uploads.tapatalk-cdn.com/201...ffdd97e1bc.jpg Sent from my Pixel 2 XL using Tapatalk |
Re: Let's see your Bomber body 4 Attachment(s) CarterFab full sides, AMF Deluxe hood, AMF rear panel w/tow hook, AMF stainless skid, T-Bone Racing nylon roof, Desert Rat RC Design stinger - when freshly assembled and last pic with JEC Racing SS links/trailing arms and other wheelset: |
Re: Let's see your Bomber body http://u.cubeupload.com/SavageDarwin...38281209x1.jpg http://u.cubeupload.com/SavageDarwin...43241024x7.jpg Planning on redoing side panels as I drilled one screw hole wrong and hood is stock lexan just painted to match better till I get the bug to make my own. |
Re: Let's see your Bomber body A lot to like in here and it's just begun Edit: I gotta lose the stock panels ....but i got some loco bloke inside http://www.rccrawler.com/forum/membe...4427-64877.jpg |
Re: Let's see your Bomber body smog, that's definitely the most hilarious facial expression I've ever seen on a driver figurine... :lmao: |
Let's see your Bomber body Quote:
I made these a year or so back. Hood and roof panels. https://uploads.tapatalk-cdn.com/201...af2f2646f4.jpg The left one is the Harley Wraith panel, IIRC. The right is the Bomber. https://uploads.tapatalk-cdn.com/201...0cb84ea9d5.jpg Came out like this. https://uploads.tapatalk-cdn.com/201...8a100098a7.jpg |
Re: Let's see your Bomber body Those patterns are great for someone looking to do their own. Note the scale inside so they print the correct size. "thumbsup" For anyone considering those patterns but using aluminum, get a can of spray contact cement like the 77 (drawing a blank on the mfg) and glue the patterns to the aluminum. Cut out using whatever method you have. A pinch of acetone or laquer thinner will remove the glue and the pattern comes off, clean metal. File or sand the edges, shape to fit the rig. Mark the mounting holes (a little drill bit is good for locating the chassis mounts) and away you go. |
Re: Let's see your Bomber body Quote:
Correct. The red panels I made were using polycarbonate faceshields I jacked from work. Traced and cut the originals on paper and put them into a program for cutting vinyl. Then etched the poly with the vinyl cutter. Finished the cut and smoothed the edges on my garage concrete floor. LOL. Made some vinyl decals copied off of the A10 nose art and stuck them to the inside for painting. Easier than you’d think. |
Re: Let's see your Bomber body Stock panels painted a simple black, then covered with vinyl. I love the look. Durability, well... I guess they're holding up pretty well considering the thrashing that they're taking, and I think the battle scars give it character. Here are the vinyl sections that I cut. I cut each panel section out of the same area on both colors so that I can have the same pattern on both. https://farm5.staticflickr.com/4422/...83732a3f_c.jpg For my base, I painted all of the panels black. Here is the hood: https://farm5.staticflickr.com/4351/...bf80d675_c.jpg And here is the hood with the vinyl: https://farm5.staticflickr.com/4425/...79c5f1a8_c.jpg Here are the two panels on the body: https://farm5.staticflickr.com/4336/...1538072b_c.jpg Final product: https://farm5.staticflickr.com/4740/...39409dea_c.jpg https://farm5.staticflickr.com/4717/...b64839c1_c.jpg |
Re: Let's see your Bomber body Looks good. |
Re: Let's see your Bomber body Hey Brake Weight, I printed your patterns, they print huge as is, glad I have a good copier to resize them. I will see how well they actually fit soon. Seems like they are the OEM panels squashed flat and traced. V1 of this will be 26 ga. galv. If they are good, size wise (I matched mounting hole centerlines to my cage), a complete basic body (hood, sides and roof) should take maybe 10 minutes to build, complete with the mounting holes!!! How long did it take to make the lexan pieces from the face shield? |
Re: Let's see your Bomber body Maybe 10-15 minutes of cutting and smoothing the edges. Little bit of heat and bending. Then paint. |
https://imagizer.imageshack.com/v2/6...923/g4u7US.jpg |
Re: Let's see your Bomber body I made these apparently I havent take many recent pictures though. https://www.thingiverse.com/thing:3001954 https://www.thingiverse.com/thing:3126907 https://www.thingiverse.com/thing:2901135https://uploads.tapatalk-cdn.com/201...c24abc9a21.jpghttps://uploads.tapatalk-cdn.com/201...88cc366a08.jpghttps://uploads.tapatalk-cdn.com/201...ceda9830d1.jpghttps://uploads.tapatalk-cdn.com/201...5836cf8f6b.jpg Sent from my SM-N950U using Tapatalk |
Re: Let's see your Bomber body Here are those pattern pieces in galvy. Not digging the nose of the hood. EDIT: After studying this thing, round nose is fine, my body detail lines suck. Should have done a different design with the jog work. Smog's rig looks entirely different than this thing. Time for a Mulligan. https://live.staticflickr.com/65535/...f809b0f2_c.jpg20190928_100327 by MAC FAB, on Flickr https://live.staticflickr.com/65535/...321ffac0_c.jpg20190928_100402 by MAC FAB, on Flickr |
