09-29-2019, 08:01 PM | #1 |
Newbie Join Date: Jan 2019 Location: Marysville
| How to get a smaller turning radius RR10
I installed the Savox 1230 servo and a billet throw lever but I'd sure like a smaller turning radius. Any suggestions? Everything else is stock, I do like this rig.
09-29-2019, 08:03 PM | #2 |
Pebble Pounder Join Date: Jan 2018 Location: Northeast Iowa
| Re: How to get a smaller turning radius RR10
turning radius would be based on knuckles/chubs and wheelbase. you could get a longer servo horn but it might not clear the steering link. Sent from my SM-G965U using Tapatalk |
09-29-2019, 08:05 PM | #3 |
Newbie Join Date: Nov 2018 Location: US
What's your current max wheel turn? If it's turning until just before the wheel contacts the C hub, that's as tight as your turn radius is going to get. Sent from my ONEPLUS A6013 using Tapatalk |
09-29-2019, 08:12 PM | #4 |
Newbie Join Date: Dec 2018 Location: in the workshop
You can overdrive the front and/or underdrive the rear, that'll give you a better turn into radius, and it'll crawl better too. It'll track straighter at higher speeds too but might also cause extra wear to the driveshafts and tires. Sent from my ONEPLUS A6010 using Tapatalk |
How to get a smaller turning radius RR10 - Similar Threads | ||||
Turning radius? | sandrocks | Axial Wraith | 6 | 01-25-2013 09:53 PM |
Turning radius? | It usually runs fine | Redcat Crawlers | 6 | 01-20-2011 02:47 PM |
Turning radius? | stubs179 | Losi Mini-Rock Crawler | 4 | 12-14-2009 07:13 AM |
Turning radius | gunch | Duratrax Cliff Climber | 14 | 12-10-2009 08:52 PM |
Best turning radius for AX-10 ? | Parky | Axial AX-10 Scorpion | 17 | 11-10-2008 05:46 AM |
