12-14-2019, 07:20 PM | #1 |
| Hard Lean
For some reason my Bomber has a hard lean to the right. I didn’t notice it until I took off the sway bar. I have tried adjusting the preload, but it always settles back. As far as I can tell nothing is bent. Sent from my iPhone using Tapatalk |
12-14-2019, 07:34 PM | #2 |
Pebble Pounder Join Date: Jan 2018 Location: Northeast Iowa
| Re: Hard Lean
any more pics Sent from my SM-G965U using Tapatalk |
12-14-2019, 07:37 PM | #3 |
Newbie Join Date: Dec 2018 Location: Tucson
| Re: Hard Lean
How are your shocks? All filled? Sent from my SM-G975U using Tapatalk |
12-14-2019, 07:52 PM | #4 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
| Re: Hard Lean
Might be over filled on the drivers in one or both? I'd take the shocks off, compress em by hand and compare them all to each front and back. Check for sticky links. Any mods to it? |
12-14-2019, 07:54 PM | #5 |
| Re: Hard Lean Sent from my iPhone using Tapatalk |
12-14-2019, 08:18 PM | #6 |
| Re: Hard Lean
The only hardware mods are the rear-steer. I was starting to think about the shocks not being right when I posted, so I will check them. |
12-15-2019, 12:23 AM | #7 |
| Re: Hard Lean |
12-15-2019, 11:09 AM | #8 |
RCC Addict Join Date: Dec 2014 Location: So Cal
| Re: Hard Lean
Switch shocks from side to side, left on right and vice versa. If it leans the other way, its the shocks. If not, is something binding?
12-16-2019, 10:14 AM | #9 |
| Re: Hard Lean |
12-16-2019, 10:56 AM | #10 |
| Re: Hard Lean
In the one photo it looks like you're missing a spring cup on the one shock. That would do it. Do all of the shocks move smoothly and extend all the way? |
12-19-2019, 07:48 PM | #11 |
| Re: Hard Lean
My car did that from the panhard or staring link not being able to swivvle enough. I had to change the 20 degree bent ones for straight ones. It compressed funky too so it was kinda obvious. Sent from my SM-N950U using Tapatalk |
Hard Lean - Similar Threads | ||||
Crawler lean | jpedersm | Axial SCX10 II | 0 | 06-25-2019 05:58 AM |
Body lean? | Inspector86 | Traxxas TRX-4 | 4 | 08-25-2017 08:58 PM |
body/chassis lean during hard accelartion | bbking9 | Axial Wraith | 7 | 01-06-2012 01:17 PM |
Chassis Lean | rc2000 | Team Losi Comp Crawler | 16 | 10-23-2009 02:28 PM |
