01-27-2020, 05:21 PM | #1 |
Rock Stacker Join Date: Sep 2017 Location: Germany
| Mamba Monster in RR10
I reat that it is hard to get the Monster underneath the RR10's cover. Has anybody solved that problem?
01-27-2020, 08:11 PM | #2 |
| Re: Mamba Monster in RR10
I've only seen it fit by ditching the interior panel.
01-27-2020, 10:32 PM | #3 |
Quarry Creeper Join Date: Jan 2016 Location: Boulder
I had to push it back far enough to clear the back side of the battery tray. As a result, there's not a whole lot of surface area on the top of the receiver box for servo tape. I used what I could and then strapped it down with a zip tie. I did not have to remove the interior, though I think I ultimately removed the fan. I run mine almost exclusively on 2S. To be honest, I think it's overkill since the ESC can handle a lot more power so I should probably move it to a much faster vehicle. |
01-30-2020, 12:22 PM | #4 |
RCC Addict Join Date: Jun 2017 Location: Canada
The best way is to fabricate a plate over the 2 speed shift servo mount and place the ESC there overlapping the side of the cage. You would have to get inside the rig by the roof for any repair and maintenance Sent from my Pixel 2 XL using Tapatalk |
Mamba Monster in RR10 - Similar Threads | ||||
Mamba Monster 2200kv with Mamba Max Pro | jordanbottle | Electronics | 6 | 05-21-2015 04:48 PM |
