06-09-2020, 05:16 PM | #1 |
Newbie Join Date: Jun 2020 Location: San Diego
| Steering tie rod screw wont stay in
Hey all, so I recently bought my bomber and the steering tie rod screw keeps coming out. Looking in to upgrading but not sure what brand of aluminum to go to. Also, mad that the stock plastic stripped out so easily after two drives since I bought it. I did not overtighten but maybe switching to aluminum is inevitable with this truck. Any suggestions on what brand upgrade or kits. I may want to just do the front and rear linkage upgrades now too so I don't have to keep replacing plastic pieces.
06-09-2020, 05:26 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: Steering tie rod screw wont stay in
Incision Stainless link kit or JEC Racing Sent from my Pixel 2 XL using Tapatalk |
06-09-2020, 05:29 PM | #3 |
| Re: Steering tie rod screw wont stay in |
06-09-2020, 05:31 PM | #4 |
Metal links are kind of a must, I assume you have the RTR with the plastic links? If so at some point you may want to swap all of the links for metal links.
06-09-2020, 06:30 PM | #5 |
Newbie Join Date: Jun 2020 Location: Stouffville, ON, CDN
I had the same issue with my metal steering arm. So far blue loc-tite has been holding up after a run, if not I was going to glue the grub screw into the steering arm. Anything metal is an upgrade if you have plastic steering arms but I would suggest Incision stainless steel steering arms, beefier then aluminum and I may still purchase a set myself. Sent from my SM-G965W using Tapatalk |
06-09-2020, 06:57 PM | #6 |
You also should use blue loctite on everything that screws into metal. Sent from my Pixel 2 XL using Tapatalk |
06-09-2020, 07:20 PM | #7 |
Rock Stacker Join Date: May 2008 Location: 90605
A set of aluminum steering knuckles and some Loctite are advisable.
06-09-2020, 08:02 PM | #8 |
Quarry Creeper Join Date: Feb 2018 Location: East otis
Do not buy those aluminum links with the brass inserts that hold the hollow ball in. They wear out fast and are junk. The ssd titanium links with the replaceable m4 revo rod ends are the way to go. Or the incision stainless ones. Sent from my SM-G970U using Tapatalk |
Steering tie rod screw wont stay in - Similar Threads | ||||
Steering Tie Rod | Knarly Nerd | Axial XR10 | 3 | 03-19-2012 06:45 PM |
KK high clearance tie-rod vs. CKRC OTA tie-rod vs. ?? | BigB_117 | EnRoute Berg | 64 | 07-06-2009 11:20 PM |
Non Tie-Rod Steering? | Robb | General Crawlers | 26 | 06-04-2008 02:14 PM |
