12-02-2020, 08:11 PM | #1 |
Newbie Join Date: Jul 2017 Location: Mentone
| Shims for rear diff?
hi, I am trying to get some answers. I have a Bomber and I replace the locker and gears , Vanquish , for underdrive in the rear. I am having some binding , what size shims do I need to buy and where can I buy a set ? TYVM !!!
12-02-2020, 08:13 PM | #2 |
Pebble Pounder Join Date: Jan 2018 Location: Northeast Iowa
| Re: Shims for rear diff?
need some 5mm inner diameter shims and put them on the outside of the housing right where the driveshaft mounts. i use these, been great for me. https://www.amainhobbies.com/kyosho-...caAs6rEALw_wcB Sent from my SM-G965U using Tapatalk |
12-02-2020, 08:22 PM | #3 |
You just use a couple ? Thank you for the fast reply !
12-02-2020, 08:29 PM | #4 |
it comes with a bunch, just use as many as needed to tighten it up so the gears arent binding. i used 2 of the 0.3mm ones, but everyones situations are probably different Sent from my SM-G965U using Tapatalk |
12-02-2020, 09:11 PM | #5 |
So, by adding shims, the gears are shimming away from the housing, making it not tight ? Sorry, I am new to shimming. ty
12-02-2020, 09:28 PM | #6 |
the most common reason to add shims is that the gears are not meshing properly. this is usually due to the gears being jammed into each other too close. the helical design of the teeth draws the gears toward each other. to combat this, the shims are used on the outside of the axle housing, on the pinion shaft, next to the driveshaft mounting area. this creates a pulling effect on the pinion shaft, pulling and forcing it away from the ring gear. it removes the opportunity for the pinion gear to be drawn into the ring gear, thus negating any binding. hope this helps Sent from my SM-G965U using Tapatalk |
Shims for rear diff? - Similar Threads | ||||
Diff shims? | FordFixer | Axial SCX10 II | 14 | 01-14-2019 09:24 AM |
Diff shims | Straxus | Axial Yeti XL | 2 | 09-17-2015 02:59 PM |
Note on diff shims | pro mod steve | Axial Yeti XL | 3 | 04-18-2015 08:26 PM |
Diff shims!!! | axman | Axial Yeti XL | 23 | 12-17-2014 07:02 PM |
diff shims??? | MIKE OXBIG | General Crawlers | 2 | 03-08-2006 12:51 PM |
