SSD Diamond centered rear axle drive shaft options? I received my Diamond axles for my Bomber and noticed where there is a likely clearance issue with the stock rear drive shaft. I saw where others are using MIP's but I was wondering if anyone has tried the SSD drive shafts with the centered axle. Or, what other drive shafts are you guys using? MIP's are out of stock at RPP right now. Thanks! |
Re: SSD Diamond centered rear axle drive shaft options? Read my build thread |
Re: SSD Diamond centered rear axle drive shaft options? Quote:
Re: SSD Diamond centered rear axle drive shaft options? Forgot to update. I went with the SSD driveshafts and they clear fine with the centered rear axle. I'm not running the spur cover though. |
