05-21-2021, 12:40 AM | #1 |
Rock Stacker Join Date: Oct 2020 Location: San Jose
| More power?
I've got a friend that just picked up the bomber and was disappointed with the speed. Would this be over kill with a 17T pinion? https://www.amainhobbies.com/hobbywi...010201/p607216 Would it break all the innards? |
05-21-2021, 05:34 AM | #2 |
Pebble Pounder Join Date: Oct 2019 Location: Saint Louis
| Re: More power?
It’ll be very fast but you’ll lose all your low speed control with a sensor less setup like that. As far as breaking parts, that all depends how you drive it. Sent from my iPhone using Tapatalk |
05-21-2021, 08:04 AM | #3 |
| Re: More power?
If you have no plans on it being a crawler, throw the HW setup in and let it rip. If you want to maintain any sort of crawling ability, a sensored system would be way better. Most would run a Mamba X/motor of choice setup but if you want to stick with HW, I would look at the XR8 SCT ESC combos. Since the Bomber is a AR60 based truck, the likely failures are axle gears, axle housings, c-hubs, knuckles, trailing arms, and front links. The most common way to make them reliable is to replace everything from the skid plate to the wheels. |
More power? - Similar Threads | ||||
Gt power high power headlight system problem | yetifreak11 | Electronics | 9 | 12-30-2016 04:36 PM |
Losi Lipo Works On Flight Power/Thunder Power Balance plate?? | fa1rch1ld | Electronics | 0 | 01-18-2010 11:46 PM |
Thunder Power 1350 Pro Power 30c review | Just Zach | Electronics | 35 | 09-04-2009 09:12 AM |
