12-21-2008, 01:32 PM | #201 |
Quarry Creeper Join Date: Aug 2005 Location: Lake Mary
Cool, time for some optional pull points and bumpers
12-21-2008, 05:37 PM | #202 |
RCC Addict Join Date: Dec 2005 Location: Tucson
Rc planet has them in stock 269.99 so much for early 09'
12-21-2008, 08:06 PM | #203 |
Quarry Creeper Join Date: Sep 2006 Location: Orange, CA
12-21-2008, 08:13 PM | #204 |
Pebble Pounder Join Date: Nov 2008 Location: Southwest, MO
Is it going to have a on-the-frame servo mount when it releases? Or will this come later? thanks.
12-21-2008, 10:24 PM | #205 |
Newbie Join Date: Mar 2008 Location: cleveland
Can we see a video of the truck in action |
12-21-2008, 10:58 PM | #206 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
chassis is sick just wish it was metal instead of plastic.
12-21-2008, 11:05 PM | #207 |
RCC Addict Join Date: Jul 2006 Location: So Cal USA
12-22-2008, 12:51 AM | #208 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I'll try and get some video shot/edited in the near future. It is steel. | |
12-22-2008, 01:33 AM | #209 | |
Newbie Join Date: Aug 2007 Location: Denmark
Something wrong with the pdf-file? | |
12-22-2008, 01:51 AM | #210 |
Rock Stacker Join Date: Dec 2008 Location: Honolulu
For those of you wondering about alternate scale bodies, I made a few measurements and looked up some stats. First, as previously mentioned here, wheelbase of the SCX10 is 11.5", with an overall width of 9" (outer tire to outer tire) OK, I busted out my Mountaineer (Bruiser) body and was pleased to see the wheelbase (center of wheelwell to center of wheelwell) was right at 11.5", and the overall width of the body is 7 1/2" (fender flare to fender flare) - so the stock SCX tires would only stick out about 3/4" on each side. Pretty much perfect I'd say! Now, I don't have a Tundra (yet!) but searching the Tamiya website, it lists the Tundra as having a 12 1/4" wheelbase (3/4" longer than SCX10). Overall length is listed as 18 1/4", which is very close to the mountaineer body, so I'm guessing the body width will be close also. From what Bender says, and is pretty obvious from looking at the pics, it should be relatively simple to merely purchase slightly longer suspension links to lengthen the SCX10's wheelbase 3/4" to match the Tundra body! Since we're adding longer links, you could also run longer scale shocks for a "lift kit" as well - I plan to anyway. Now, Axial / Bender, could one of you measure something for me please? I'd like to know the overall width from outer 12mm hex to outer 12mm hex. I know this would be different from the stock Scorpion, because the hexes are narrower on the SCX10. The reason I ask is I'd like to build a truck with your chassis and use the soon-to-be-released scale Blackwell (2 1/2 ton military copy) axles from RC4WD. I plan on using 2.2 Tires/wheels with a Tundra body. RC4WD specs show the Blackwell axles to have an overall width of 8" from hex to hex. Last edited by swatdoc; 12-22-2008 at 01:54 AM. |
12-23-2008, 07:53 AM | #211 |
Quarry Creeper Join Date: Mar 2005 Location: The 2one7
Please tell me these will be available separately!
12-27-2008, 06:41 PM | #212 |
Quarry Creeper Join Date: Sep 2007 Location: Duchesne
this would make a great chassis to build a 2.2 scaler on also. are those the stock ax-10 axles? or did you guys build new axles that are narrower?
12-28-2008, 01:16 AM | #213 |
RCC Addict Join Date: Nov 2007 Location: CALI "209"
im so glad these are not released yet , cause all i can afford is to read and drull over these posts right now. christmas was expensive |
01-01-2009, 10:00 AM | #214 |
Newbie Join Date: Nov 2008 Location: Fishkill
Ok its early '09. Where are these things? |
01-01-2009, 11:15 AM | #215 |
Quarry Creeper Join Date: Aug 2008 Location: Northern, Mi
Any updates as to when these wheels will be available? I NEED them. My rig has no wheels.
01-01-2009, 03:56 PM | #216 |
Rock Crawler Join Date: Sep 2007 Location: Denmark
| Patiences it a virtue At least thatīs what I am telling my self |
01-01-2009, 04:25 PM | #217 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
Any word if there will be just a chassis kit available?
01-01-2009, 05:41 PM | #218 |
HDMM: Is this what you r talking about? http://axialracing.com/ftp/ax30525_frame_set.html |
01-01-2009, 10:34 PM | #219 |
Pebble Pounder Join Date: Dec 2008 Location: Side of a MOUNTAIN
Stupid question, maybe- What is the shortest wheelbase that can easily be done? This thing would be perfect for my D90 project, but it's kinda short as far as wheelbase. Selectable diff locks somewhere in the future for Axial? |
01-02-2009, 12:11 AM | #220 |
Quarry Creeper Join Date: Jul 2008 Location: looking for that perfect setup
are there any vids up yet?
