| | #1 |
| Quarry Creeper ![]() Join Date: Sep 2006 Location: Lake Forest
| Axial 61-90mm Aluminum Shock Set
AX3009 61-90mm Aluminum Shock Set - 7mm Piston (2pcs) Visit here for more info: http://www.axialracing.com/ftp/ax10options/index.html Last edited by Axial; 12-16-2008 at 06:47 PM. |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
| very nice! scale projects will love these |
| | #3 |
| RCC Addict ![]() Join Date: Apr 2008 Location: Sacramento
| Those are nice , but they need to make a threaded shock body for the AX10 shocks... |
| | #4 |
| Rock Crawler Join Date: Jul 2006 Location: Kelowna BC Canada
| how wide are the springs???? |
| | #5 |
| Quarry Creeper ![]() Join Date: May 2008 Location: Mansfield, PA
| Wow, those are extremely nice scale shocks I love the dual rate spring setup...great job Axial Last edited by Trugg; 12-16-2008 at 08:44 PM. |
| | #6 |
| I wanna be Dave Join Date: Oct 2006 Location: Laying low...
| Looking good...no more leaky leaky? |
| | #7 |
| | #8 |
| Axial Team Driver ![]() Join Date: Feb 2005 Location: OC
| Those are beautiful!! Probably work great on the comp rigs with short shocks too. Great work! |
| | #9 |
| Rock Crawler Join Date: Jun 2008 Location: Lemont, IL
| the "reservoir" looks hollow, check the bottom and it looks like te top and bottom caps are still plastic....dont get me wrong, they look really good, and if they do have aluminum caps they will probly end up on my scaler, but im done with plastic shock housings and caps |
| | #10 |
| Newbie Join Date: Dec 2007 Location: here
| can you get replacement spring to stiffen of soften the rate? or is this just done with adjuster and oil level? |
| | #11 |
| Newbie Join Date: Dec 2008 Location: Virginia Beach
| Nice! |
| | #12 |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
| So is the travel similar to other 90mm shocks? I ask because you have what looks like a short body and a compression stop on the shaft. My HPI A723's are listed as 62-87mm so it seems like the travel is similar, maybe more. If these will easily replace the A723's then I'd love to go with them. Spherical ball in the cap and the small diameter body are top notch features. Great shocks Axial. |
| | #13 |
| Quarry Creeper Join Date: Nov 2008 Location: N. California
| Those are cool but I am assuming the reservoir is not functional, is it just for looks? |
| | #14 |
| There is nothing wrong with plastic shock caps... I actually prefer plastic caps. The problems with leaking and caps popping off is caused by plastic shock BODYS...not shock caps. |
| | #15 |
| Quarry Creeper ![]() Join Date: Nov 2008 Location: Roseville,Ca
| those shocks look pretty cool. |
| | #16 |
| Rock Stacker Join Date: Mar 2007 Location: yakima
| Nice work axial! The shocks look great. I think the plastic caps with balls on top are a great idea. So much easier to setup without binding and fuel tubing. You might sell a boat load of these shocks minus the resivour and in a few different lengths. |
| | #17 |
| These are aimed primarily at the scaler market. We haven't tested them as a comp shock for use on the AX10. (we have something better planned there The reservoir is a looks only touch, but they also include the no reservoir cap as well. Thanks, Axial |
| | #18 |
| IVE BEEN SZCZERBOTAGED!! ![]() Join Date: Mar 2007 Location: roland,ar
| looks good! ill be getn a set! |
| | #19 |
| Newbie Join Date: Aug 2008 Location: SoCal
| when will these be shipping? |
| | #20 |
| Newbie Join Date: Nov 2008 Location: piedmont
| i want to see a picture of them on something |
| Thread Tools | |
| Display Modes | |
