Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Axial SCX-10
Thread: SCX10 Optional Springs
Old 12-16-2008, 06:35 PM   #1
Axial's Avatar
Default SCX10 Optional Springs
  • Fine tune your SCX10 to any driving situation or style
Part Info
AX30200
Spring 12.5x20mm 3.6 lbs/in - Super Soft (Red) - (2pcs)
AX30201
Spring 12.5x20mm 4.32 lbs/in - Soft (White) - (2pcs)
AX30202
Spring 12.5x20mm 5.44 lbs/in - Medium (Green) - (2pcs)
AX30203
Spring 12.5x20mm 6.53 lbs/in - Firm (Yellow) - (2pcs)
AX30204
Spring 12.5x20mm 7.95 lbs/in- Super Firm (Blue) - (2pcs)
AX30205
Spring 12.5x40mm 2.7 lbs/in - Super Soft (Red) - (2pcs)
AX30206
Spring 12.5x40mm 3.6 lbs/in - Soft (White) - (2pcs)
AX30207
Spring 12.5x40mm 4.08 lbs/in - Medium (Green) - (2pcs)
AX30208
Spring 12.5x40mm 5.44 lbs/in - Firm (Yellow) - (2pcs)
AX30209
Spring 12.5x40mm 6.81 lbs/in- Super Firm (Blue) - (2pcs)
Visit here for more info: http://www.axialracing.com/ftp/ax10options/index.html
Axial is offline   Reply With Quote
Old 12-17-2008, 12:44 AM   #2
tomer's Avatar
so these fit inside the shocks? if they do where can i get some.
tomer is online now   Reply With Quote
Old 12-17-2008, 12:46 AM   #3
No - these are part of the dual spring shocks for the new scale kit. They go on the outside.
2JSC is offline   Reply With Quote
Old 12-17-2008, 10:29 AM   #4
Yo Axial, what is the height of these springs? I need some of these with more spaced out coils but will wait now if these are tall enough.
Thanks.
O.C.D. is offline   Reply With Quote
Old 12-17-2008, 11:32 AM   #5
Hey Axial,
Is there a place I can get some more specs on the SCX-10 itself? Like it's wheelbase, track width, ETC. I've looked around but I have not found anything.
Thanks!
WheelTravel is offline   Reply With Quote
Old 12-18-2008, 11:15 AM   #6
Axial's Avatar
Thanks.
They are 12.5x20mm and 12.5x40mm (diameter x height).
Thanks,
Axial
Old 01-20-2009, 08:43 PM   #7
If you go to the axial website the vehicle specs are all there.
My boss ordered 2 of these. The second it hits the store its mine.
RC Mechanic is offline   Reply With Quote
Old 01-27-2009, 05:56 PM   #8
I joined the Band!
Default ?
Will these fit in my AX10 Scorpion? What I really want to know if the shocks (AX30090) will fit in my AX10?
grimgard is offline   Reply With Quote
Old 01-27-2009, 06:23 PM   #9
Axial's Avatar
I'm sure you could get them to fit, but they were not developed to be used on the AX10. The spring rates and overall oil capacity will be a major performance hit.
But you won't have to wait long for some shocks that will work on your AX10.
Thanks,
Axial
Old 01-27-2009, 06:37 PM   #10
I joined the Band!
Thanks,
Axial
Good news! Finnaly some Axial shocks designed for my AX10 that will lower it without modding the heck out of them.
