02-05-2009, 11:47 AM | #81 |
Newbie Join Date: Feb 2009 Location: Bangladesh
| steering servo from the front axle
I did was re-locate the steering servo from the front axle to the chassis with a couple home made brackets that tie into the stock frame cross members. I was just able to shoe horn it in underneath the battery tray out front and get very minimal bump steer. It took a few tries to get the placement right, but it seems to be working
02-05-2009, 02:48 PM | #82 | ||
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I got the first inner fender well mocked-up using the tops off some blank CD cases. Now, I'll trim it up to fit tightly inside the body and spray them all flat black when I'm finished. | ||
02-05-2009, 04:06 PM | #83 |
Got the first one roughed out so the body fits over it. I'm still going to have to trim a little more off the backside by the door, so it's not visible from the outside.
02-05-2009, 04:17 PM | #84 |
Pebble Pounder Join Date: Mar 2008 Location: yes
Perhaps you could just cut a slot in the crease of the fender and bend the offending piece back under the body and out of sight. It would at least help protect the inside of the truck better than the hole left by an over-trimmed fender.
02-05-2009, 05:02 PM | #85 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
That is pretty creative. I had a couple of those sitting around here the other day before trowing them out lol. Very nice.
02-05-2009, 05:26 PM | #86 |
Rock Stacker Join Date: Nov 2006 Location: lake forest, CA
Lookin great!
02-05-2009, 05:39 PM | #87 |
Quarry Creeper Join Date: Jan 2006 Location: .
The spare tires, and fans make this thing look badass. I think it needs a fast brushless motor. It is just asking to be jumped. Cool build Brad. |
02-06-2009, 07:16 AM | #88 |
varcor.org Join Date: Aug 2005 Location: 757
damn brad, that's one sweet build up. i've always love the pre-runner look especially when you mix in a little rock crawler influence. that would make a cool limited edition model... |
02-06-2009, 09:58 AM | #89 |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
Amazing build! Any plans on adding some LED lights?
02-06-2009, 10:08 AM | #90 | ||||
I'll probably add lights at some point as well. | ||||
02-06-2009, 04:59 PM | #91 |
I like the use of the short standoff between the drag ink and tie rod end to ward off the bump steer. I see that your 1-2-3 blocks made the move with you |
02-07-2009, 12:01 AM | #92 |
Pebble Pounder Join Date: Jun 2008 Location: nampa
thanks for the idea on the inner fender i did it on mine it looks good we need pics of them painted please and great job |
02-07-2009, 02:40 PM | #93 |
Pebble Pounder Join Date: Nov 2008 Location: Southwest, MO
Do you just have one mounting point for your inner fenders? All i can see is one.
02-07-2009, 10:58 PM | #94 |
RCC Addict Join Date: Feb 2008 Location: Nevada
this truck looks awsome, love the fans Sweet idea on the inner fender well |
02-08-2009, 12:21 PM | #95 |
Newbie Join Date: Feb 2008 Location: klamath falls
Very nice work Bender , as usual ! Ive been working on a prerunner useing some SCX10 parts. What wt. shock oil do you recommend ? The SCX shocks I bought didnt come with any oil and so far nobody can tell me the right wt. anyway - Keep it up , it looks great ! |
02-08-2009, 09:54 PM | #96 |
Pebble Pounder Join Date: Apr 2008 Location: brookland
do the 1.1 prerunner style trucks have independant front suspension? would it be possible to adapt maybe a tmaxx front gearbox into the build somehow? great work so far!
02-09-2009, 10:11 AM | #97 |
RCC Addict Join Date: Nov 2007 Location: Nine Mile Falls, WA
Bender very nice work. I would add some rubber mud flaps to the back sides of the wheel wells. That would add to the look plus cover the space possibly where the wheel well comes up a bit short in the rear. Tire inner tube rubber works real good for mud flaps. Jason |
02-09-2009, 10:27 AM | #98 | |||||||
02-09-2009, 10:29 AM | #99 |
Well then the next step is a custom set of bush wacker flares.........lol Jason |
02-09-2009, 01:07 PM | #100 | |
Got the rear inner fender wells mounted up. Had to cut them to go around the rear body mounts, and shim them out from the frame so the spare tires would fit between them. It's a tight fit, but should work fine. | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-scx-10/157616-updates-my-scx10.html | ||||
Bender’s Custom SCX10 Prerunner Build | This thread | Refback | 10-04-2011 04:24 PM |
