Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Axial SCX-10
Thread: can you run leafs on a scx10 chassis?
Old 02-04-2009, 07:52 PM   #1
Default can you run leafs on a scx10 chassis?
i really like the scx10 chassis but im really wanitng to build something with leafs. is i possible to mount leafs to the chassis without having to cut it up? (incase i ever want to go back to links)
4ONDFLR is offline   Reply With Quote
Old 02-04-2009, 10:09 PM   #2
I heard somewhere that axial is going to be putting out mounts for leafsprings.....? Other wise you'll have to modify existing mounts or make your own.
MiddleT is offline   Reply With Quote
Old 03-02-2009, 12:09 PM   #3
DBR
I don't see why it would be that hard. Seems to me that all you would need to do is cut a spacer for the c-channel frame that will help support the shackles. The axle even has holes on top that would seem to line up with using leaf springs. If I was more adventurous or skilled for that matter, I would give it a try. I still have to paint my body and go break something before I worry about modifying my SCX.
DBR is offline   Reply With Quote
Old 03-02-2009, 02:31 PM   #4
well the holes on top of the axels are father spaced then the chasis so the leafs would be at an anglepointing inwards to the from so the only way i see doing it would be to widen the frame even with the holes and run your shocks inside of the frame . wich i now that i think about it i think i just solved my drop bed issue on my tundra! haha yes! good luck if you attempt it i wanna see pics!
punkuup5150 is offline   Reply With Quote
Old 03-02-2009, 03:26 PM   #5
DBR
I bet someone (not my three left thumbs) dexterous enough in making small parts could make some brackets that would mount to the holes on the top of the axle. The bracket could provide a flat surface for the leaf and a mounting point for the shock. Then you could shave all of the other attachment points and have a really clean looking axle. Man!!! I thought I was saving for the Losi 1/10. Now I have to get another SCX so I can make a true scaler......
Old 03-02-2009, 03:55 PM   #6
Let's hope this dexterous person will make lots of brackets and sell them to the rest of us nondexterous people
naggalowmo is offline   Reply With Quote
Old 03-02-2009, 06:27 PM   #7
DBR
Who ever does make them, just make sure I get some kind of backhanded across the face like the red-headed step-child credit for coming up with the idea
Old 03-02-2009, 06:53 PM   #8
run the springs off mounts on the outside on the frame like a highlift
f-350highlift is offline   Reply With Quote
Old 05-25-2009, 09:28 PM   #9
Default leafs on scx 10
am putting leafs on the axial scx 10 tonight the f350 axles would work just have to drill holes in the back part of the frame and thats it front aready has the wholes to put leaf's
mysterygamer is offline   Reply With Quote
Old 05-29-2009, 03:23 AM   #10
Well did you get it done?
Old 05-30-2009, 01:18 PM   #11
yeah it work great now am just working on my nitro juggernaut
Old 05-30-2009, 05:29 PM   #12
How about a pic!!!!!
calikingcrawler is offline   Reply With Quote
Old 05-31-2009, 03:05 PM   #13
pic of the nitro juggy or the leafs onthe axial scx10
Old 05-31-2009, 03:28 PM   #14
yes i know i quoted my self but how do you uplaod pics anyhow lol
Old 05-31-2009, 04:15 PM   #15
dkf
Open a photobucket account, upload the pics to your account and post the image code in thread. Or I can post pics for ya.
dkf is offline   Reply With Quote
Old 05-31-2009, 04:36 PM   #16
http://i580.photobucket.com/albums/s...5/DSC00183.jpg
the link is the best i can do for now kinda new to posting pics on websites
Old 06-01-2009, 02:09 AM   #17
Good job! That looks trick!
fastgixxerlv is offline   Reply With Quote
Old 06-01-2009, 02:08 PM   #18
ya its not bad but i changed my mind about have leafs so going to sell the tamiya f350 axles and use axial axles instead
Old 06-01-2009, 09:42 PM   #19
What kinda leafs are those? very scale looking
Old 06-01-2009, 09:55 PM   #20
thay look like 350 leafs to me
flmudder is offline   Reply With Quote
