Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Axial SCX-10
Thread: Question for Axial (seriously)
Old 02-04-2009, 08:29 PM   #1
I <3 LS3
exesivefire's Avatar
Default Question for Axial (seriously)
I know why the choice was made to use the standard AX-10 axles in the new kit. Well I assume I know anyway...
But what are the chances that if the kit turns out to spark enough interest, you guys release a slightly narrower axle in the future?
I prefer running your axles over TLT's due to durability, and the ease of getting replacement parts. But cant quite ditch the TLT's yet due to the width on some of my builds.
I think I recall reading a post where it was considered, just wondering how much of a pipe dream it really is?
exesivefire is online now   Reply With Quote
Old 02-04-2009, 11:21 PM   #2
jimbiss's Avatar
I agree, narrower would be a nice option. I run you axles for durability also.
jimbiss is offline   Reply With Quote
Old 02-04-2009, 11:25 PM   #3
All they would need to do is make smaller housings and shafts. Not a whole new axle.
2JSC is offline   Reply With Quote
Old 02-04-2009, 11:31 PM   #4
willipmartinni's Avatar
Default and tlt look stupid
and tlt's look stupid listen up axial, we know you more than capable, and listening so do it do it
Last edited by willipmartinni; 02-04-2009 at 11:33 PM. Reason: i didnt make tlt's plural in the subject line
willipmartinni is offline   Reply With Quote
Old 02-05-2009, 12:01 AM   #5
i agree as well maybe with a bolt on portal that would bring u out to the regular axle housing that would be so sick
cooterwrenchen is offline   Reply With Quote
Old 02-05-2009, 03:21 AM   #6
how bout coming out w/ a narrow offset wheel
you should be able to get the track width narower by a good 3/4 in
NeXt559 is offline   Reply With Quote
Old 02-05-2009, 09:28 AM   #7
I <3 LS3
they did that on this kit, they made narrower hexes and ran the offset as low as they could go. problem is, I have already been doing that.
a TLT width, MAYBE a hair narrower would really do wonders, we have option to go wider to match the track width we need, but you cant go narrower if needed..
Old 02-05-2009, 10:16 AM   #8
Practicing my launchs >:)
Robbob's Avatar
if they went narrower axles though for the existing truck its gonna throw other things off I would think.
frame width, shock mounting/angles ....... virtually have to redesign more then just axles.
Robbob is online now   Reply With Quote
Old 02-05-2009, 10:25 AM   #9
OCCUPY RCC!
dezfan's Avatar
If they were to sell a "kit" which included narrower axle housings and shorter shafts, crawlers would do what they have done since the start, they would make it work.
I would love to have a set of narrower axles.
dezfan is online now   Reply With Quote
Old 02-05-2009, 10:35 AM   #10
Exactly. It isn't that the Scorpion needs narrower axles, it's the fact that some custom builders want narrower axles for thier other projects. Instead of turning to outdated and sometimes hard-to-find parts, a narrow case and axle kit would bring with it all the benefits of the Axial design and parts support.
Mad Scientist is offline   Reply With Quote
Old 02-05-2009, 10:42 AM   #11
I <3 LS3
BINGO!
Leave the kit be, I just want to buy axles, and make my own stuff..
Old 02-05-2009, 10:49 AM   #12
I like the idea of the narrow axle kit. They should also make the case more scale looking and make it leaf spring compatible. It would also be nice if they would use the Tamiya dimensions on the leaf spring mounts to introduce some sort of standard leaf mount dimensions, just like 1.9" wheels and 12mm hex etc...
If Axial aren't up for it, I certainly am. It was already on my todo list
Katan is online now   Reply With Quote
Old 02-05-2009, 10:51 AM   #13
cato's Avatar
I'm sure the COST of re-tooling everything for the few that want narrower axels, would be astrinomical
cato is offline   Reply With Quote
Old 02-05-2009, 11:01 AM   #14
OCCUPY RCC!
dezfan's Avatar
That's what they said about the ring and pinions too.
IMO, scale is now really starting to grow, w/ the release of the SCX, it's only going to get bigger.
Old 02-05-2009, 11:08 AM   #15
Powered by Awesome
TwistedXT's Avatar
dang.. beat me too it!
whats the term? "its easier said then done"
this may be a good oportunity for aftermarket to step up on a narrow housing kit. anyone.. .anyone....
TwistedXT is online now   Reply With Quote
Old 02-05-2009, 11:10 AM   #16
With the right hex and wheel, you can get a narrow stance. I got an axle set to 8 3/8", wheel to wheel.
sierradmax is offline   Reply With Quote
Old 02-05-2009, 11:23 AM   #17
You're close in width but I still can't build a 1.9 comp rig using Axial axles.
2.4.2 - Vehicle track width is limited to a maximum of 8 inches.
I'm planning out my 1.9 on paper and would really love to use Axial axles but I'm probably going to use TLT's due to width.
John82601 is offline   Reply With Quote
Old 02-05-2009, 11:24 AM   #18
Like I said, its on my list.
I would still like to hear what Axial have to say about the possibility of a factory kit?
Old 02-05-2009, 11:46 AM   #19
sloppy's Avatar
yeah right take a look in the scale section how many pages of scale builds are there??? how many 1.9 trucks would switch to axials from TLT's.. throw that BS cost thing out the window... 10 grand for a new axle case mold and one new axle side is not a huge cost... based on the current scale market..
axial is doing what all companys do trying to recycle parts to ride a segment of the hobby.. they should have made the right axle for the new 1.9 thing..
sloppy is offline   Reply With Quote
Old 02-05-2009, 12:26 PM   #20
The rear axle could be made narrow really easy by just narrowing the straight axle adapters and shortening the shafts. Any aftermarket company could do this easily. I have plans to narrow a set of axles for 1 of my builds. You could also build a c hub with 1 side of the lower link mount on it and cut the axle housing short, then bolt up the new c hub and run cut down axles. Why someone after market hasn't done this is beyond me.
ZUKMAN is offline   Reply With Quote
