Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Axial SCX-10
Thread: can I cut the links?
Old 02-04-2009, 09:36 PM   #1
Default can I cut the links?
Hey guys I need to shorten my axial links in the back about an inch or so. Rather then buy shorter links is there enough thread inside the links to just cut them to size? Maybe a half inch off each side?
porklops is offline   Reply With Quote
Old 02-05-2009, 11:26 AM   #2
2006 2.2 National Champ
BENDER's Avatar
You can cut the links shorter, because the links are hollow all the way through. But, you will end up cutting all the internal threads off if you shorten them by an inch. You'll have to go back and re-tap the links with an M3x.5 tap.
BENDER is online now   Reply With Quote
Old 02-05-2009, 11:44 AM   #3
I had to do that , but I just used all thread and stainless sleeving, looks great!
Ill keep the stock links for another project or just sell them, they look nice
nmanuel01 is offline   Reply With Quote
Old 02-05-2009, 11:12 PM   #4
Mr. Series Champ!!!!
finishline's Avatar
so there threaded 1/2 inch on each side i thought it was an inch each side on the longer links?
finishline is offline   Reply With Quote
Old 02-05-2009, 11:39 PM   #5
I play with TOY TRUCKS
Rpp Hobby's Avatar
What he said and I have an inexpensive 3mm drill and tap set that is a godsend to have on your tool box just for instnaces like this.
Dubro T-Style Tap Handle (1)
Click the image to open in full size. 1 Handle
372 Tap & Drill Set 3mm
Click the image to open in full size. 1 set Handle sold seperatly
Rpp Hobby is offline   Reply With Quote
