| | #1 |
| Newbie Join Date: Apr 2008 Location: andorra
| Excuse my english ... Hi, I'veen trying to shorten the wheel base of an scx-10 from 29 cm to 26,5 cm to fit a LR3 newbright body. I've done new links shorters, upper an lower (1,25 cm each) and joined again in the car and the wheel base did not change as much as I thought Does anyone have the exact length of the upper and lower links? Do I have to make new holes in the chassis to fix in a new place? If you have pictures better to understand ... Thanks, pipo |
| Sponsored Links | |
| | #2 |
| Rock Crawler ![]() Join Date: Apr 2008 Location: SO CAL
| Check mine out, I'll post the lenghts when I get home |
| | #3 |
| Newbie Join Date: Jul 2009 Location: Perth, Western Australia
| Yeah i'm looking to run the New Bright LR3 on an scx10 chassis too and the link sizes would be a great help??? |
| | #4 |
| Throwing Grenades ![]() Join Date: Jul 2004 Location: Sending illegals home one Hayabusa at a time.
| Since the links are triangulated you lose some of the effect of shortening your links. You will probably need to go to a 4-link to keep from binding the 3 link when shortening the links. |
| | #5 |
| Pebble Pounder Join Date: Apr 2007 Location: Near Oxford, UK
| what wheelbase is the D3 body? if it is 11'' then you need 85mm lower suspension arms according to Axial. (as thats whats going on my D90 build) |
| | #6 |
| Quarry Creeper Join Date: Feb 2008 Location: Boise
| I just shortened the rear links to 70mm on my scx10.... seems to work just fine. I did loose some articulation, but since you won't get proper tire tuck on a LR3, it works out just fine. You'll also have to hack off a bit of the upper tri-link piece, can't tell you how much, just trial and error it. Had mine out on the rocks yesterday and you'll love it when you get it done! ![]() |
| | #7 |
| Newbie Join Date: Jul 2009 Location: Down by da beach
| wow that looks sweeeeet |
| | #8 |
| Newbie Join Date: Mar 2011 Location: Murfreesboro
| Thread Tools | |
| Display Modes | |
