Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Axial SCX-10
Thread: Pea-Ta's SCX 10
Old 02-09-2009, 11:43 PM   #1
Thumbs up Pea-Ta's SCX 10
Hey everyone Id like to first start off by saying great forum and great builds. This is the site that convinced me to get an scx 10. I'm going to refer to other build threads to get ideas for my own scx. I'm still on the fence on what body to get the diablo body is catching my eye at the moment but I would like something more scale.... Im gonna head down to target, walmart etc to see if I can grab someting.
Some pics of the first run.
Over all i'm very impressed with the quality and performance of the scx10. I know I will have to do some suspension tuning to have it perform the way I want it to. But, for now, I will leave it be.
Pea-Ta is offline   Reply With Quote
Old 02-09-2009, 11:49 PM   #2
how are you likeing the brushless power in it and which one are you running? interested to see its speed
punkuup5150 is offline   Reply With Quote
Old 02-10-2009, 12:11 AM   #3
Love the brushless, Its a mamba max 5700 geared 87 14 (stock) It's not as fast as I thought or want it to be but a few extra gears up on the pinion will be able to fix that; I have lots of torque to spare.
The programing on the mamba is
25% brake
50% reverse
0% punch control
0% drag break
high start power
lowest timing
Linear throttle and brake.
First Vid: some water/mud
http://www.youtube.com/watch?v=kGrx5C_3Q5o
I'll see if I can get some vids of some trails.
Old 02-10-2009, 12:21 AM   #4
Mr. Series Champ!!!!
finishline's Avatar
do you experience any cogging with that motor esc combo at slow speeds, or crawling ?
finishline is online now   Reply With Quote
Old 02-10-2009, 12:38 AM   #5
I have no cogging. I attribute this to the "high start power" and the low gearing. There was minimal cogging when the esc was set to "low start power" but now It feels as smooth as a brushed motor. I will keep everyone updated as to how it performs when I start gearing it up.
I ran a 7.4v 3000 mah battery threw it and the motor was barely above ambiant temperature and the esc was about the same. I'm gonna pick up a 16 tooth pinion tomorrow and see how that does.
Old 02-10-2009, 12:48 AM   #6
finishline's Avatar
how long did the batery last? i have the same motor, esc and batery set up that i could use.
Old 02-10-2009, 01:08 AM   #7
Is the mamba max waterproof?
I have one sitting around and would like to use it, but i like going in the water to much and wasn't sure on it's waterproof-ness.
07_FJC is offline   Reply With Quote
Old 02-10-2009, 01:09 AM   #8
About 20 min of crawling (20% throttle) and 15 min of full speed trails.
Old 02-10-2009, 01:13 AM   #9
Its water resistant, I've splashed it a couple times (including in my vid) and no damage yet. the way I mounted it I have the usb port down and taped up with electrical tape. I also ran some ca glue along where the pc board meets the case.
Old 02-10-2009, 09:40 AM   #10
25% brake
50% reverse
0% punch control
0% drag break
high start power
lowest timing
Why do you use lowest timing? What difference does it make? I have no clue about this timing shit..
fastolsen is offline   Reply With Quote
Old 02-10-2009, 10:41 AM   #11
Befriending Champ 09'
crunky's Avatar
i see you only got a few post counts, so hey welcome.
you have found the most informative site this side of mars.
very killer looking project you got there. keep up the good work.
here's a few links i will share...
the search bar will be your best friend.
SEARCH
yes there is a classifieds section.
Classifieds
make it be known your here....
INTRO
... and lastly here is a great place to start.
Tips and Tricks... the bibles
enjoy your stay.
crunky is online now   Reply With Quote
Old 02-10-2009, 06:46 PM   #12
Thanks crunky and thanks for the links.
@ fastolsen Timing on a BL motor is kinda like a brushed, the higher the timing the more amps it draws meaning more power, however, more heat is generated. As for my setup, I haven't ran it through it's paces yet so I like to keep things cool and work my way up. Timing does not really matter too much if you are running nicd/nimh. Once you start running higher end lipo's you will see a big difference when you adjust timing.
Just picked up a 16 tooth losi pinion and installing later...
Went to the park by my house to mess around. ran It on the slash track we setup, It took the jumps very well. After about 15 min of that I started crawling. The truck performed well but I was not getting enough traction, I would get half way up and then I would spin all fours.
Is it possable to have too much torque?
Old 02-10-2009, 11:35 PM   #13
i would b interested in a video showing it running wide open, i have a 13.5 turn brushless novak setup in mine, but surely yours would be much faster than mine. any chance of posting up a video? thanks
ajcloud is offline   Reply With Quote
Old 02-11-2009, 01:16 AM   #14
I have the same setup I could install in my scx I just built yesterday and am curious in seeing a full speed and crawling video.
By linear throttle curve do you mean straight from bottom to top at a 45* angle or straight across from left to right????
gta3wheeler is offline   Reply With Quote
Old 02-11-2009, 07:42 PM   #15
@ ajcloud: I'll see if I can do a vid tomorrow, I have to work on some bugs at the moment with the esc. I'll explain further down.
@ gta3wheeler: A 45 degree incline from left to right.
So while I was out testing the 16T pinion, I rolled the truck and demolished my servo. It was my traxxas servo that I pulled from my slash. So not much of a loss there. Now I have a HS-645MG.
Once I put the 16T into my rig It wasn't going much faster so I started investigating. turns out I forgot to tighten my slipper after I installed the wheels on it. Now it's fast. I am getting slight cogging when crawling at very low speeds so I'm still working that out. I ether have to adjst the throttle curve or advance timing. I'll see which works best.
Old 02-13-2009, 02:47 PM   #16
I got some testing in yesterday after school. I also got some vids. I tried to edit them together but my computer was not wanting to listen so I just uploaded some raw vids.
Speed test:
http://www.youtube.com/watch?v=49rYHcz1qdc
Jumping/crawling:
http://www.youtube.com/watch?v=pQkByXtkFH4
Bashing/ Crawling:
http://www.youtube.com/watch?v=nnnTE4VFT0M
In summary of yesterdays testing, speed seems to be up to the range to where I want it, but low speed torque I still need to tune. It only coggs a little but it's still too much for me. I'm gonna pick up a 15 T pinion the net time I'm down at the LHS; also, I'm gonna bump up the timing a little bit to give me a little more punch. 11.1v is also in the future.
Now I have a problem. I need to extend the wheel base of my rig which I can do by getting longer links but what is the recommended way of doing this? I need to extend about 1 inch.
Old 02-13-2009, 04:09 PM   #17
Axial's Avatar
You can't add too much to the front without running into clearance issues with the servo. But you can add quite a bit to the back.
We used the following parts front and rear to extend the wheelbase to 12" (305mm).
AX30518 Threaded Aluminum Pipe 6x98mm - Grey for the lower links.
AXA1418 6x6mm Spacer - Grey for the upper link.
We also offer the grey links, posts, and spacers in different lengths so you can fine tune the length to exactly what you need. All the part info is below:
http://www.axialracing.com/ftp/grey_...s_spacers.html
Axial is offline   Reply With Quote
Old 02-13-2009, 05:20 PM   #18
Sweet! Thanks =)
Edit:
So I need the wheel base to be close to 13 in, 330mm..... I think I will only be able to extend the rear due to servo clearance issues.
If I put the 106mm links in the rear it will give me 305mm..... If I do both I will get 320mm which I can live with....
If I mount the servo to the frame, will I still have clearance issues in the front?
Old 02-13-2009, 08:24 PM   #19
Default Water!!!!!!!!!!
It stopped raining.... you know what that means!!!
http://www.youtube.com/watch?v=duCd9E3raSQ
Old 02-18-2009, 09:40 PM   #20
So I got my titan body painted but I seem to have misplaced my decal sheet so I contacted pirma and they are sending me another one =)
And then a video:
(it seems all my vids look like crap...... I'm gonna try converting / compressing it first then uploading.... will that make a difference?
http://www.youtube.com/watch?v=Sh6YmvD9F2g
