03-14-2009, 08:32 PM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: Aurora Colorado
| Is anyone running 2.2 on their SCX
I was looking through the picture archive and only saw 1. Are there disadvantages to running 2.2 over 1.9? I will be running an HPI Bronco body which is for an 1/8th scale and thought it would look better with 2.2's. What are your thoughts and opinions?
03-14-2009, 09:30 PM | #2 |
Rock Stacker Join Date: Sep 2006 Location: Alberta
yes im running 2.2 mud slingers on mine but I also had to make a 1" suspension lift so I would still get my articulation.If your going to use 2.2 then I would recomend some sort of suspension lift or else your suspension will be highly limited.If you stick with the 1.9s then no modifying will be needed but you wont get the extra axle cleerance that you would get from the 2.2s. As far as body choises goes... As far as I know I dont think that you would have to modify or cut the body when useing 1.9s but you might have to do some trimming if you use the 2.2s Last edited by renny; 03-14-2009 at 09:33 PM. |
03-16-2009, 01:38 PM | #3 |
Quarry Creeper Join Date: Feb 2008 Location: US
hey renny, I was wanting to do this as well for more traction\clearance. Could you tell me, what is the effect on the stability? It seems like it would make the truck more likely to tip over unless maybe you use offset rims. Thanks for the info! |
03-16-2009, 01:43 PM | #4 |
Quarry Creeper Join Date: Feb 2009 Location: Rocklin, CA
09-30-2010, 12:16 AM | #5 |
Pebble Pounder Join Date: May 2010 Location: brisbane australia
Im running 2.2 on mine with 110mm lift looks awesome and goes places |
09-30-2010, 06:29 PM | #6 |
Quarry Creeper Join Date: Jul 2010 Location: PNW
I've got 2.2s on mine and it goes anywhere you want it to. |
09-30-2010, 06:50 PM | #7 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
2.2's are do-able on the SCX, and will take you just about anywhere. Here's an old one of mine on PL Hammers. The wider tire gives you more stability if you don't lift it too high.
09-30-2010, 07:00 PM | #8 | |
I wanna be Dave Join Date: Dec 2008 Location: ?
09-30-2010, 08:55 PM | #9 |
Rock Crawler Join Date: Jul 2008 Location: Dutch Oven - AZ
Up-sizing to 2.2's is by far my favorite upgrade. The effect on stability is so minimal, I can barely notice. BUT THE EFFECT ON PERFORMANCE IS EPIC! 2.2s will take your SCX-10 to places that 1.9s just can't. You won't be able to corner quite as fast, but hey, my 1:1 Honda Odyssey will corner alot more stable than my Jeep Wrangler with a 4 inch lift and 35in MTs. I chose a short 2.2 tire, the Proline Badlands, standing at 5.06 inches tall. Heres a pic... |
09-30-2010, 11:42 PM | #10 |
Quarry Creeper Join Date: Feb 2009 Location: In my house
Yup Runnin' Losi Rock Claw 2.2's on mine, and by far the best single up-grade I have done to the truck. the effect on handling is minimal, but the gain in all around performance is down right astonishing With the right set up it will handle BETTER than stock and crawl way better than stock. With the right choice of wheel and tire, it will look better than stock as well |
10-01-2010, 08:38 AM | #11 |
Rock Crawler Join Date: Aug 2008 Location: Somewhere in the Sierras.
Running 2.2s on mine also. Much better performance. |
10-01-2010, 09:43 AM | #12 |
Quarry Creeper Join Date: Mar 2009 Location: in a van down by the river
| two two |
10-01-2010, 03:22 PM | #13 |
Pebble Pounder Join Date: Jan 2009 Location: THE OTHER STATE OF MAINE
So I am considering 2.2 super swampers on my honcho if i dont mind trimming do I still need suspension lift to get my same travel? What shock would you guys reccomend if i need lift?
10-01-2010, 08:06 PM | #14 |
RCC Addict Join Date: Apr 2008 Location: Old Hickory
Just about finished putting 2.2 Flatirons on my honcho...Narrowed the tires and rims so there just about the same as a 1.9 rok lok. havent got to run it yet but heres a pict. I may lift the body a hole or two but will still use the same shocks. |
10-01-2010, 08:25 PM | #15 | |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
Those look like a good size! What wheels work best when running 2.2's? Id like to run some flatirons or the new tsl's. I may haveto ditch the handbro's and get some longer shocks though. Last edited by Cableman; 10-01-2010 at 08:27 PM. | |
10-01-2010, 09:01 PM | #16 | |
Thanks...the wifey is a HOTTIE....I don't know what 2.2 rims yet, I only have 2 sets and they are both stock axial 2.2 rims. I just finished testing on my mini rock pile and I dont see me putting the rok loks back on any time soon...killer hook up and better speed...would like to find a narrower offset rim guess it's time to do some reasearch. I do like how they truck looks like a actual tacoma now with full size axles...it still looks somewhat scale-ish | |
