06-22-2009, 09:35 AM | #1 |
Rock Crawler Join Date: May 2009 Location: 354
| help
hi guys, i starting to build my SCX-10 last night and I noticed that when I put the axle together it feels that it's tight won't spin freely is this how it's suppose to be or is there something else. iv'e check and recheck and everything seems to be fine. im am new to this any help would be great. |
06-22-2009, 10:04 AM | #2 |
Rock Crawler Join Date: May 2007 Location: floriduh
Mine was the same just for the rear axles, though it doesn't seem like it is as bad as your's, it seems like a tight gear mesh. I'm gonna run mine for a while and see if it seats in. The bearings on the pinion shaft are seated fully in the axle housing right? I used to bearings stacked on top of eachother to seat it in the houseing, seemed to work, but still got alittle noise. Idk.
06-22-2009, 10:15 AM | #3 |
Quarry Creeper Join Date: Feb 2009 Location: Rocklin, CA
make sure the pinion bearing is seated all the way in. It is a really tight fit. I had to take a pair of needle nose pliers and pull from the outside to get mine seated. |
06-22-2009, 10:27 AM | #4 |
Rock Crawler Join Date: Apr 2009 Location: Pa
06-22-2009, 02:44 PM | #5 |
Newbie Join Date: Mar 2008 Location: ft collins
I had the exact same problem as you.... and it wasn't being caused by improperly seated bearings, anyway here was my solution Rough Rear Axel |
