![]() | #1 |
Rock Stacker Join Date: Aug 2008 Location: Porto, Portugal
What is the best way to start a tube bed? The material is aluminium tube 6mm. i don't have a clue to where i start... ![]() |
![]() | #2 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Well, for a start, I'd re-think your choice of material. Steel brake line will be a whole lot easier to braze than aluminum tubing. Aluminum can be brazed, but it of course takes a very specific rod and flux. Aluminum also oxidizes horribly when heated to a temperature sufficient to melt the rod, and this makes it even more difficult for the flux to wet the aluminum and make the rod adhere to it properly. And if you're brazing directly to the steel SCX10 chassis, I'm not sure if you can even braze aluminum to steel. I don't think it's possible. I've never done this myself, I only watched the process once. I was told that it was a much more difficult process to master than brass-brazing steel... |
![]() | #3 | |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
| ![]() Quote:
Steel is a good choice, or you can use brass tube/rod. | |
![]() | #4 |
Yes i know its more difficult but i'm going to give it a try and i already have the solder (durafix) for it. The thing is, where do i start? |
![]() | #5 | |
| ![]() Quote:
Give it a shot and see how it does ![]() Then the real task will begin - learning about bending tubes. I think the bending accurately part is waaaaay harder than actually joining tubes. There's been a ton of tube builds going on here lately. I just finished one, Pinchflat and Kaetwo are finishing up a couple, theres a bunch of others. Search around and you'll get plenty of ideas. And as far as the brazing steel to aluminum part of it, check out Wreckers Toyota. All the tube work is completely bolt-on: Wrecker's Toyota Last edited by Big Mike; 10-09-2009 at 02:12 PM. | |
![]() | #6 |
RCC Addict Join Date: Nov 2008 Location: never been
only thing that stopped me going durafix is waiting since i was hawt to get on with brazing, it seemed rasonably priced though but i needed quick access to supplies so i went the other route. bending tubes to spec is kinda hard and it hindered me on my project, post-up your experience on the durafix rods and GL on your project. here`s a link on durafix http://durafix.com/ |
