10-16-2009, 08:59 AM | #1 |
Rock Stacker Join Date: Sep 2009 Location: Austin
| How much do the long lower links extend the wheelbase?
They look to be about 1/4" longer, but due to them being at an angle, I doubt that this means 1/4" longer wheelbase for each end. Basically, what I am looking to figure out is If I were to do the longer links on one end, how much longer would it be? At both ends? How much longer? |
10-16-2009, 09:59 AM | #2 |
RCC Addict Join Date: Jan 2006 Location: Irritable Isle
I put them on mine. I'll try to get a pic up this weekend.
10-16-2009, 10:01 AM | #3 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
Not quite sure what links you are talking about. Are you talking about changing the rod ends on the lower links? If you change the length of the lower links by changing the rod ends, then you will need to do the same for the top. This way, you can keep the pinion angle the same. As for the length. I have changed the rod ends on the links and if you replace both sides, you get just under 1/4" wheel base extension. |
10-16-2009, 12:20 PM | #4 |
10-16-2009, 01:40 PM | #5 |
10-16-2009, 11:17 PM | #6 |
The stock WB is about 11.5" With both sets of the long plastic links used front and rear with 90mm upper links, my WB is 12" |
10-17-2009, 01:32 AM | #7 |
Pebble Pounder Join Date: Jun 2009 Location: Santa Cruz Mountains
Are you talking about the stock ax-10 link length of 98mm compared to scx-10 that are 91mm? I'm building my SCX-10 from scratch and I ordered 91mm links, if they are to short I'm going to switch to Jato ends. I like to drill and tap them out to 8-32 and run the bigger ball ends. |
