![]() | #101 |
Rock Crawler ![]() Join Date: Jun 2008 Location: South Ogden, Utah
this is the one i styled it after ![]() ![]() |
![]() | #102 | |
Moderator Rule Breaker ![]() Join Date: Feb 2004 Location: Austin, Tx
| ![]() Quote:
http://www.pirate4x4.com/forum/showt...ghlight=tacoma | |
![]() | #103 |
Totally awesome day at the scale comp today.... |
![]() | #104 |
Looks like cold,muddy,snowy fun!
![]() | #105 |
Rock Crawler Join Date: Aug 2008 Location: Bristol Va.
| ![]() I agree with Badd, it's a bad ass truck but was looking for a F150 and didn't see it, ain't that the F100 Proline body?
![]() | #106 | ||
| ![]() Quote:
Yeah its the F100 body... And remember these pics are from quite while ago if you want to start telling me that it doesnt have a summit trans and a 13.5turn tekin brushless setup... | ||
![]() | #107 | |
| ![]() Quote:
![]() | #108 |
![]() | #109 |
Pebble Pounder Join Date: Feb 2008 Location: Bala Cynwyd
Excellent F100/F150/brushed truck/brushless truggy build ![]() ![]() what kind of rod ends are you using? are the output shafts on the summit tranny 5 mm? Looks like I have to start collecting new parts... I am really digging the 2sp brushless setups |
![]() | #110 |
Quarry Creeper Join Date: Sep 2010 Location: West Linn
i still dont understand how you get the body off.... Nice looking rig though. It's looking like a beast! Soon i'll be getting 1.9 rok lox. I wish i could fit 2.2's on mine.... ![]() ![]() ![]() ![]() ![]() |
![]() | #111 | ||
| ![]() 13.5 tekin rs ![]() dr side mount, trans rotated to lower cg ![]() pass side mount ![]() Quote:
I have enjoyed this truck enough to recomend it to anyone. lots of work=lots of fun! Oh and the outputs are 6mm and the mip cvd end that fits it is part #8137 Quote:
![]() no cage ![]() cage ![]() some other details winch drum ![]() splash panels held on with 2mm screws ![]() ![]() | ||
![]() | #112 |
Quarry Creeper Join Date: Jan 2004
That thing looks like a beast, and it'll will go through anything that gets in it way ![]() Great build ![]() ![]() |
![]() | #113 |
Where did you get your winch line ? Still can't enough of this rig! |
![]() | #114 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
this is one sick tank you have there
![]() | #115 |
| ![]() The winch line is 80lbs test "dacron" from the local anglers inn. Im trying to find it online. its not expensive it is definalty strong enough, and looks scale. Only drawback is it does abraid on the rocks if it gets smashed by the tubing. Ive added zip ties around the bumpers so it doesn't see that abuse
![]() | #116 | |
| ![]() Quote:
![]() | #117 |
looks like a trip to cabellas would be fun they have this line and others http://www.cabelas.com/product/Fishi...9680|104612580 |
![]() | #118 |
| ![]() Quote: ![]() |
![]() | #119 |
Finally gotten through some 1:1 cars/shows, and have some time to play/work on toys. Last scale comp i made it to i trashed another axial plastic housing, So I called the partners in crime at Tammies hobbies and ordered up some of the 3r aluminum housings, worked them up and have gotten the front one installed. Also bolted the 8t motor in, need to wire it up. All these parts are going to end up in the "too much thinking TTC" rig, but might as well test and drive till that thing gets completed. I Signed up for the scale nats so that is definitely some motivation. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by willipmartinni; 03-18-2011 at 06:46 AM. |
![]() | #120 |
Rock Crawler Join Date: Feb 2010 Location: in a Fishbowl watching time go by
WOW the new axle should hold up .... My boy always talks about the time u used some winch line to fix your broken axle on that fun run ... |
