10-26-2009, 09:31 AM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: Tulsa
| F350 scx10 tr?
Has anyone got a DIY or an scx10 rocking the tamiya f-350 body? just cab or full? I am about to order an scx10 tr and a 350 body if its not too hard to get slapped on. Thanks
10-26-2009, 10:36 AM | #2 | |
I streched my wheelbase 3/4" by screwing on 10mm tubes to the upper and lower links. Last edited by AreCee; 10-26-2009 at 10:38 AM. | |
10-26-2009, 11:18 AM | #3 |
Newbie Join Date: May 2005 Location: upstate
Scx10tr does not have screw on links. They are molded plastic. You will have to increase your wheelbase from 11.4 inches to that of the ford body. I used all thread and tubing. Came out fine. Just takes time and patience. |
10-26-2009, 11:48 AM | #4 |
Quarry Creeper Join Date: Jul 2009 Location: Bel Air, MD
Why not just use AX10 links? My brother had grey metal links with his SCX10...not sure whys yers didnt....I have a full set of Green links and bars if you want
10-26-2009, 12:28 PM | #5 |
10-26-2009, 02:18 PM | #6 |
what about if i just want the cab, i really dont want the bed, and i definetly dont want to have to extend the wheel base id like to keep it at stock
10-26-2009, 03:13 PM | #7 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
10-26-2009, 07:41 PM | #8 |
will there be any mini metal work needed? can it be done with very little fabrication?
10-27-2009, 08:09 AM | #9 |
Quarry Creeper Join Date: Apr 2007 Location: Barrie, Ontario
This is my 350 sitting on a SCX-10 frame |
10-27-2009, 05:37 PM | #10 |
RCC Addict Join Date: Nov 2008 Location: never been
cab only will need some sort of flat bed or sumthin unless you want to leave the rear barebones. look around at the build threads to get an idea of what you need to do.
10-27-2009, 07:42 PM | #11 |
ive been lookin at builds all day i cant find any scx10 with an f350 that has anything on how they did it, i found one but its metal plate fabbed, and thats way out of my league lol i want to leave barebones and a spare tire mounted and maybe shorten the rear frame and links |
10-29-2009, 08:29 AM | #12 | |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
10-29-2009, 10:46 AM | #13 |
my tr is in finally but no f350 top yet, and it seems the motor stops a little past midway towards the end of the chasis, is it the same size chasis as the origonal scx10??
10-30-2009, 10:47 PM | #14 |
I completed building my rolling chassis tonight and I lined the F350 body up with it....perfect fit. The wheel arches on the body are right above the tires, so no worries.
