07-28-2010, 03:01 AM | #41 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
| I believe they are 60mm. I used the kit on my SCX but am getting some binding in the steering. It's making my servo very warm. I've disconnected the draglink from the knuckle and it turns freely. Once the drag link is mounted it's all tight again. Anyone else have this issue? If so what'd you do to fix it? Also on the interference issue. I am running the stock shocks, spacers removed and at full compression on either side I loose maybe 1/8" of travel. At full compression on both sides I loose more but You'll never compress both sides at once while wheeling. |
07-28-2010, 08:03 AM | #42 |
Rock Stacker Join Date: Jun 2010 Location: Arvada, CO
I have not gotten the kit yet, but i've been studying the pics here and here for a long long time... and to me it looks like on the drag link you would need one of a couple things... Either some bent rod ends so the ball is not at maximum angle at ride height. OR high clearance knuckles OR a spacer inbetween the servo arm and the drag link so the drag link isnt at such a dramatic angle. rckjeep question for ya: on your up travel are any of the links hitting the frame or another link to limit your flex? Or does the panhard(track) bar hit the axle diff? it looks from the pics that the top 3rd link would contact the panhard bar maybe... edit: rckjeep, is yours a Honcho or a short wheel base one? Last edited by zrxw13; 07-28-2010 at 08:52 AM. |
07-28-2010, 11:32 AM | #43 | |
07-28-2010, 11:46 AM | #44 | |
In your experiance was there a gain in suspension travel when you went from stock to this kit? | |
07-28-2010, 07:18 PM | #45 | |
I think you have been mislead what this kit is about, You've never get more travel by changing link geometry(of course interference issues aside). This kit is about scale looks. all solid axle trucks produced now run a panhard bar. This kit only hinders travel slightly, if installed correctly. Yes you may need to tweak your setup if it's not stock. I'm using Traxxas lowers that may not be the exact same length as the stock SCX. I am however using the stock shocks & towers. So ride height should be pretty darn close. Without the panhard bar you will get bumpster, which is way they designed it with a 3 link. I love the kit works great. Is it perform better than the stock configuartion or even a 4 link, no. Is it more scale with the similiar performance, definitely. | |
08-08-2010, 12:52 PM | #46 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
I just installed some tra2742 links on the bottom of my shocks. It raised the ride height a hair but pretty much have full articulation and i have a hair more then half of the shock bump stops cut out.To raise the steering bar I installed a longer spacer on the steering knuckle inplace of the small one. I found the one on the stock y 3link worked well.
09-27-2010, 11:55 AM | #47 |
Rock Stacker Join Date: Apr 2010 Location: Coram, NY
any reason why the axial 4-link truss cant be used instead of the 3-link w/ panhard?
10-01-2010, 05:53 AM | #48 |
10-10-2010, 10:21 PM | #49 |
Rock Stacker Join Date: Aug 2010 Location: Good. Green. Oregon.
Got my Honcho CMS kit installed and I just had some questions and comments on it...... My question in now that I have it installed, it seems that my Honcho turns better one way that the other. Is this just an adjustment to the servo, or is this a characteristic of the CMS kit? I have adjusted all the end points on radio and everything, but thought I would ask. My comments: First, this a very nice kit, with beautifully finished parts. Well thought out, and in my opinion, worth the $45+ that I paid for it. But, I have to say that for that $45, this kit really should come with some detailed instructions on how to install it. I know, the instructions are on this forum and ORCRC, but even those are far from detailed, and are, sorry to say, very poorly written. There are spelling and grammar issues, skipped steps, etc throughout the instructions. I just think that for such a professional product, the instructions should reflect that same professionalism. I am in no way knocking the product, as it is wonderful. I just think that the company that produces it would be taken so much more seriously, with some well put together instructions. |
01-11-2011, 04:43 PM | #50 | |
Pebble Pounder Join Date: May 2005 Location: Long Island NY
I just built my Honcho, been into rc's for years not an expert on crawlers yet and I am thinking about ordering this kit as well. This is not the first post that I have come across where the poster has had issues with the kit and its instructions. I havent ordered my kit yet but I plan on doing a "How To Install Video" so that we can at least give others a chance to better understand how the install should go.. I am not sure if there are any video's posted on You Tube or the net on this kit but I do know that from digging around the board I have found plenty of useful pictures and posts to get me by.. | |
01-18-2011, 06:12 PM | #51 |
Newbie Join Date: Dec 2009 Location: Layton, UT
I've had the Hand Bros. kit on my truck for over a year now, and have no complaints at all about performance or binding anywhere. I do have a question for those who are more knowledgeable with steering and suspension geometry than myself ... I want to get more steering angle from my truck, how would I go about doing so? I've got a longer servo arm installed and that did add a small amount. Maybe its' my steering servo or radio gear not giving me enough servo travel? I definitely plan on keeping the kit on my truck, but I will be switching to custom links when I drop TRex axles on my truck ... leaf springs will be going out back. Hand Bros. |
01-19-2011, 01:45 PM | #52 |
| The mount for the panhead bar mounts to the same location as the Axial 4 link truss. In theory you could four link the front and not have the panhard bar but then you kind of defeat the scale-ness of the design in the first place & you'll end up having bump steer as the suspension cycles.
01-26-2011, 04:03 PM | #53 |
Pebble Pounder Join Date: Jul 2009 Location: Lehigh Valley, PA
| Does anybody know what the exact differences are? Looks like the Honcho kit has the panhard mount farther towards the front of the servo mount? And I assume the upper link is longer on the Honcho? Ayone know the exact length for each kit? Any other differences?
01-27-2011, 01:43 PM | #54 |
Quarry Creeper Join Date: Jan 2008 Location: Hollister
has anyone used these kits with leaf springs?
02-09-2011, 05:36 PM | #55 |
Quarry Creeper Join Date: Jan 2011 Location: Hurricane
I ordered the kit for a Honcho and they sent me just the SCX10 kit. Can anyone tell me what is different or what parts I may be missing?
02-14-2011, 09:19 PM | #56 |
Quarry Creeper Join Date: Nov 2005 Location: dallas
04-17-2011, 01:32 AM | #57 |
Newbie Join Date: Jan 2011 Location: casper
| trouble with steering travel
I am having trouble with the steering traveling more one way than the other. I have longer shocks on my truck and am wondering if this is why. Any suggestions on how to fix this problem would be awesome.
04-23-2011, 11:29 AM | #58 | |
Rock Stacker Join Date: May 2010 Location: Killeen
I just installed this on my honcho and the servo horn hits the servo mount limiting my ability to turn left. if you have a honcho, do not buy this kit. i bought it because i saw so many builds using this kit. i hate it, going on ebay tonight. | |
04-23-2011, 11:51 AM | #59 |
Rock Stacker Join Date: May 2010 Location: Canada
The RC4WD kit is a perfect setup for a Honcho. Using a 3 link setup on the front, and their included steering link, it's a perfect setup really. No bumpsteer at all.
04-26-2011, 01:16 PM | #60 |
Ok. so after some tuning and adding spacers to lower the servo by a mm or 2. this is a great kit. Gonna keep the hand brothers 3 link cms now. works great after some minor changes. i added 2 shims to where the servo mounts to the servo mount. this brought the servo down a little. plus i have the bplt and nut on the servo horn with the nut on the lower side. i had it facing up first and that does not work out so well.
