Hand Brothers steering kit install instructions Hand Brothers steering kit install instructions . |
i found that if you dont have stock scx10 links sizes this wont work... |
Is it normal for my SCX10 to have the whole truck shift to one side when compressing the whole front end down? I know it sounds confusing but when i push down on the front, it does not go down level. It shifts slightly to the drivers side (front of truck is facing you). Ill post up some pics of what i mean if it sounds all too confusing. ser3100 is online now Report Post Edit/Delete Message |
OK. The only reason i ask is it looks wierd. Plus i kept hearing about how critical it was to use the right rod ends and such or else. But if its normal than it is what it is. Ill post up pics tonight anyways. |
The offset of the chassis during compression may vary depending on your setup. I needed to make custom links all around since I'm using a slightly shorter shock than stock. Using the included/stock link lengths, my chassis sat offcenter, and went WAY offcenter during compression. Now it's all good, and barely noticable. |
can you post pics of your setup? Ill post pics tonight. |
I've never been a big fan of panhards or 3 links for that matter. I delete the whole panhard deal, make 2 upper links and mount to one side of the Hand Bros. axle mount. A double triangulated 4 link has no need for a panhard, unless the uppers and lowers are angled the same direction. |
Clearance issue The instructions states to use the stock hardware to attach the panhard to the servo but I don't have clearance for a nut between the servo and the servo bracket because with this kit the bracket swings under the servo. It doesn't help that kit comes with three brackets and my servo came with 4 more. |
Can you use VP high steer knuckles with the handsbro steering and panhard on the honcho? |
Not a big fan of 3 links either . . . . . . And why would you give up a double triangulated four link for a three link? I am converting an ARTR to a scale build, so all I bought was the SCX10 frame. That's why I have all the orange aluminum links. I purchased the Hand Brothers CMS steering kit. It arrived today, and I've spent the last two hours installing it, and then taking it off (well, most of it anyway), and putting the stock front suspension back on. I did not use the included aluminum (drag) link, any of the stainless steel screws, or the aluminum 3 - link mount. I did end up using the servo mount. I put a 2MM spacer in between the end of the drag link and the servo arm, and another 6MM spacer between the tie rod and the drag link. I kept the stock Axial Y-link front suspension. I think it is more scale looking than the 3 link they did, and the geometry works better. I HAVE NO PROBLEMS WITH THE FRONT END GOING OFF CENTER during suspension compression. The quality of the parts is VERY GOOD - the servo mount and three link mount are very nicely machined, and the fit and finish is good. I don't like the stainless steel screws - they don't match the black ones that came on my truck, so they stand out and look stupid. . . . So I paid $47 for a nice servo mount . . . and a bunch of extra parts that I'll never use. OH WELL ! |
This is my SCX10 http://i750.photobucket.com/albums/x...ewpaint009.jpg |
Funny you mention this. I installed mine last night and removed it right after discovering the panhard bar hit the diff under compression severely limiting up travel. I considered doing what you have done, but in the interim I will leave it stock. It works muck better. |
hand bro steering? will this kit work with a tr? |
I considered bending the PH bar, but that would ultimately end up in the need for a longer bar. I made the decision to hold off befor heavily modifying the kit because a was and still am considering selling it. It is a nice kit and offers a more realistic appearance. I'm just not sure the benefits out way the stock config. That's just me, nothing against the HB kit. I did see where another member used this kit in conjunction with the stock 3 link. That seems to me the best alternative... |
This kit is designed to work with the stock set up...If you modified your suspension then you will have to change the kit to met your needs... The intent of the kit is to be more realistic in apperance.... As for the SS screws....We are from the PNW and they dont rust...That is why we supply them .... Thanks...Chad |
what new length links do you need after installing the HB kit.the stock 106mm links are now to long |
