| | #1 |
| Newbie Join Date: Nov 2009 Location: South Africa
| Hi Guys, not sure if anyone has asked this but are any of the ax10 intergy hop up parts comaptible with the scx10? Namely: Integy ax10 Shock Set (yes/no)? Axial ax10 Body Post Green (yes/no)? Axial ax10 Heavy Duty Steering Block (yes/no)? Axia ax10l Chassis Linkage (yes/no)? Axial ax10 Integy Main Chasiss (yes/no)? Axial ax10 Integy Lower Suspension arms (yes/no)? Axial ax10 Integy Steering linkage (yes/no)? Axial ax10 Servo Mount (yes/no)? Axial ax10 Integy King Pin (yes/no)? Cheers :? |
| Sponsored Links | |
| | #2 | |
| On the lookout for Rocks ![]() Join Date: Mar 2006 Location: Monroe, Louisiana
The stock shocks are why better than the AX10 ones. Stocks are 90mm, AX-10's are 110mm. Body posts will work with some mods, what's wrong with the stock ones? All axle components are exactly the same. Why would you replace the stock SCX-10 chassis with the TVP (Twin Vertical Plate) Comp chassis? The Lower Links will prolly extend your WB some. | |
| | #3 |
| backwoods crawler.. ![]() Join Date: Oct 2009 Location: backwoods of ny
| i just asked this question a little bit ago-really would like to know though.... |
| | #4 |
| i bought the SCX10 TR which comes with plastic linkage arms. I really want to upgrade these to the aluminum arms like the kit has. the rest is just to pimp it out a little. |
| | #5 |
| Rock Stacker Join Date: Oct 2009 Location: Fort Worth, TX
| parts needed to convert the TR to kit grey links. AXA1411 Axial AX10 RTR Hardware Upgrade Kit (includes all of the link ends and extra bits needed to convert to kit links) AX30516 Axial Threaded Aluminum Pipe 6x106mm Grey (1) AX30517 Axial Threaded Aluminum Pipe 6x33mm Grey (1) AX30524 Axial Threaded Aluminum Pipe 6x91mm Grey (4) AXA1414 Axial Spacer 2x6x3mm Grey (1) AXA1416 Axial Spacer 4x6x3mm Grey (6) AXA1418 Axial Spacer 6x6x3mm Grey (4) AXA1429 Axial Post 7x60mm Grey (4) Qunatities in Parenthesis are amounte neded to convert the truck. The aluminum pipes and posts come 2 to a bag and the spacers come 6 to a bag so you will have left overs to share with friends. Tower has everything but the AX30524 pipes in stock. Price to convert at online prices is about $85.00. DO NOT USE THE AX10 COLOR CHANGE KIT as the pipes and posts are the wrong length (has 98mm pipes and 55mm posts) How do I know this?. My wallet STILL hurts. I keep repeating "Next time, buy the kit. Next time, buy the kit. Next time, buy the kit..." |
| | #6 |
| GP40X, Many thanks thats extremely helpful and has completely rescued the contents of my wallet. I agree, next time buy the kit!! |
| Thread Tools | |
| Display Modes | |
