| | #1 |
| Quarry Creeper Join Date: Nov 2005 Location: Los Angeles, CA
| will trail honcho come with 4-LINK TRUSS (AX80043 PARTS TREE)?? i kno they started including it with the TR... whats the 4 link truss for anyways? does it make the truck perform better? Thanks |
| Sponsored Links | |
| | #2 | |
| Death before Dishonour ![]() Join Date: Dec 2007 Location: Moncton, NB, Canada
If you go on Axial's site and look at the instruction manual for the Honcho, you can see there aren't any 4-link trusses, just a 3-link. Last edited by canadianbacon; 11-30-2009 at 01:11 PM. | |
| | #3 | |
ok so a good upgrade for the trail honcho would be the 4-link truss for front and rear? | |
| | #4 |
| RCC Addict ![]() Join Date: Oct 2008 Location: Houston
| 4 link truss rear with the hand bros steering kit front is the best option in my opinion. Either way I do not believe you can't have it in the front without moving the servo anyway. |
| | #5 |
| | #6 |
| so i should upgrade the rear 2 the truss 4 better performance? would i loose my alum. links? or would i b able 2 use em? also will it change the wheelbase at all? |
| | #7 | |
| Quarry Creeper Join Date: Dec 2007 Location: CA
so I replace the original 60mm. to a new one with 75mm. After the installation, my rig work fine. It's not gonna changing the wheel base but it's related to the axle angle. Last edited by flybird; 11-30-2009 at 08:25 PM. | |
| | #8 | |
| | #9 |
| Pebble Pounder Join Date: Oct 2008 Location: albuquerque
| I know on axials website in the blog section there is a write up on what you need to use and do to install it on the TR and 1rst SCX. That should carry over to the new one as well. If not its not very hard to make your own links. I did that with my TR and i like it alot better. |
| | #10 |
| | #11 | |
| | #12 |
| RCC Addict Join Date: Jan 2009 Location: Crawlifornia
| The axial 4 link truss WILL work with the servo onhe axle. You can still utilize the front 2 servo mount posts. So 4 link front and rear is doable. I used one on the rear of my honcho and love it. I used 106mm links top and bottom. Didn't do the front because I plan to use the hand bro kit. |
| Thread Tools | |
| Display Modes | |
