03-18-2011, 01:42 AM | #201 |
RCC Addict Join Date: Jan 2010 Location: Barboursville, WV
| I love threads like this...full of good info. Any updates to the rig? |
07-12-2011, 12:10 PM | #202 | ||
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I flipped the mounts for the rock rails up 90*, then drilled new holes in the frame to match, which moved the rails up closer to the body. Quote:
http://www.axialracing.com/blog_posts/754600000 A few teaser shots of the conversion. I should have action shots and video soon. Last edited by Grizzly4x4; 08-18-2014 at 03:31 PM. Reason: fixed link | ||
07-12-2011, 12:31 PM | #203 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
such a tease.....
07-12-2011, 02:02 PM | #204 |
They look right at home.
07-12-2011, 02:12 PM | #205 |
RCC Addict Join Date: Dec 2009 Location: Rock Bouncin' with the Patented Technique
Sweet!
07-12-2011, 02:27 PM | #206 |
Nice conversion Bender! Now you need to convince you bosses to make a special diffy cover that holds a second pinion gear so these axles can be used for multi-axle builds. |
07-12-2011, 02:47 PM | #207 |
Rock Stacker Join Date: Sep 2010 Location: streetsboro
I Love it
07-12-2011, 09:01 PM | #208 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
Cool set up, I like the extra width.It needs front fenderwells. |
07-12-2011, 09:01 PM | #209 |
Newbie Join Date: Feb 2010 Location: The Real DownEast America
What about the axle housings being swapped front to rear, so that the the ditch side tranny drop is more inline with a pig offset to the same side? Then just a motor reversal? It would be okay on straight cut gears on the r&p's- so there's no load on the coasting side of a beveled type gear cut? Or does this notion create a conflict with the suspension links and driveshafts being too close? The driveline angles look pretty whack going from the tranny output on the right over to axles offset to the left. I thought it would be clever to fit a scaler with the typical axial center spun diff in the rear with KC/Gunnar longer beef toobs, and the offset Wraith axle up front for a more scale setup. ...Don't mind me, I get dreamy sometimes. |
07-12-2011, 09:36 PM | #210 |
RCC Addict Join Date: Mar 2007 Location: Penngrove
Those axles look great on there, just need to swap the trans outputs to the drivers side (mirror trans). So when did you say the Wraith axles will be available as a kit??? |
07-12-2011, 09:50 PM | #211 |
I figured the mirrored tranny already to be the easiest solution. Just assumed he'd have it mirrored anyway. But, He must have his reasons for no mirror job. Would definitely line up nicely with a mirrored tranny. Perhaps it does put the driveshafts too close to the links. I went Wraith pic hunting after I posted, to see where it drops stock. Looks like it is already dropping on the left side? |
07-12-2011, 09:51 PM | #212 |
Rock Stacker Join Date: Jun 2011 Location: Kaneohe, Hawaii
BENDER, Your rig is an absolute hardcore beast |
07-13-2011, 09:19 AM | #213 | ||||
Thanks for the compliments guys. Quote:
07-13-2011, 09:38 AM | #214 |
Quarry Creeper Join Date: Jun 2008 Location: anchorage
| Looking awsome, like the new axle width on that rig. Keep us posted on how she performs!
07-13-2011, 02:39 PM | #215 | |
Did you have the four little set screws in the top of your axle housings? You know the ones that help keep dirt and debris out? Last edited by Natedog; 07-13-2011 at 05:56 PM. | |
07-13-2011, 07:21 PM | #216 |
Rock Stacker Join Date: Feb 2011 Location: Alberta, Canada
looks awesome! How much width did gain with the wraith axles?
07-14-2011, 07:12 AM | #217 |
Quarry Creeper Join Date: Nov 2010 Location: right here!
07-14-2011, 09:13 AM | #218 | ||||
The ratio for full width axles under a Toyota or Jeep, to Wraith axles under a Honcho is almost perfect. | ||||
07-15-2011, 05:17 PM | #219 |
Quarry Creeper Join Date: Nov 2008 Location: N. California
The first thing I thought when I saw the Wraith axles was... I want those under my Honcho. Can't wait to see more of your rig with these axles. |
07-15-2011, 05:27 PM | #220 |
RCC Addict Join Date: Mar 2007 Location: MS Gulf Coast
Sweet! Can't wait to do this to my latest creation. They don't seem to be too much wider than the stock axles,but maybe a little more stable with the Wraith axles. Looks good. |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-scx-10/221956-benders-honcho-now-sporting-wraith-axles.html | ||||
Wroncho Action Shots | This thread | Refback | 10-05-2011 01:50 PM |
