10-23-2011, 10:00 PM | #261 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
Ive got my wroncho done (it works well) any body got wronchos done to show builds /picts? Drawbacks driveshafts (mine are scx/ax) and link set ups. Pics ideas any body?
10-25-2011, 08:52 AM | #262 | |||
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Nice! | |||
10-25-2011, 10:10 AM | #263 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
Hey Brad It's about time for ax10 axle redeux, right? You should tell Axial everyday that the masses want an updated axle similar to the AR60, but proper width and link mounts, and doesn't really need to be OCP. Just removable diff cover would be great along with new uni axles and accepts XR10/Wraith type 8deg knucles What do you think? |
10-26-2011, 01:50 PM | #264 |
Newbie Join Date: Oct 2011 Location: Bakersfield
| 2.2 gear ratio
I just bought the Proline TSLs and I was wondering if you changed the gear ratio on yours. I have a stock AXIAL Honcho Motor and ESC. What do you reccommend? Also I put 100mm Axial shocks with red springs. Was that a good move or bad move? Thanks |
10-26-2011, 02:40 PM | #265 | ||
The 100mm shocks will raise your ride height a little, as well as your center of gravity. But, that could be a good thing if you run in large bowling ball sized rocks a lot. For steep flowing rock, a lower ride height would be better. | ||
10-26-2011, 02:57 PM | #266 | |
RCC Addict Join Date: Mar 2011 Location: easton
mines not finished yet but im running 1/8 savage shocks with the ax10 and scx10 frames. its taller than a gallon of water/ milk! | |
01-01-2012, 07:45 PM | #267 |
Rock Crawler Join Date: Jul 2008 Location: Dutch Oven - AZ
| Re: Bender's Honcho............Now Sporting Wraith Axles
Hey Bender, Couple questions about the Wroncho build... Did you stretch the wheel base to 13.5in simply because you wanted to, or did you have to stretch it to accommodate functionality of the wraith axles? Would the wraith axles have any issues running at a 12.5in stock Honcho wheelbase, or would they just look a little funny so close together? Otherwise, seems pretty straight forward: 1)Invert shock mounts 2)Bend upper links 3)Add XR-10 Rod ends Couple pages back, you even discuss link lengths, which eliminates the guesswork!!! Thanks. |
01-04-2012, 10:09 AM | #268 | |
| Re: Bender's Honcho............Now Sporting Wraith Axles Quote:
The rest of the conversion is fairly straight forward, there are a few small issues that come up, like upper link driveshaft clearance, but nothing major. | |
01-04-2012, 10:36 AM | #269 |
Rock Crawler Join Date: Apr 2008 Location: Albany
| Re: Bender's Honcho............Now Sporting Wraith Axles |
01-06-2012, 04:28 AM | #270 |
Newbie Join Date: Dec 2011 Location: Rockhampton, Queensland, Australia
Awesome rig mate, got a few ideas thanks |
01-06-2012, 09:09 AM | #271 |
01-12-2012, 07:59 PM | #272 |
Rock Crawler Join Date: Aug 2010 Location: Esko
Hey Bender, I just have a quick question for you. I know you moved the rear axle back, but did you move the front axle forward some to? If so, how much? Thanks for any info.
01-13-2012, 09:03 AM | #273 |
| Re: Bender's Honcho............Now Sporting Wraith Axles If I remember right the front axle is in the stock location. I will double check when I get home though. |
01-21-2012, 02:51 PM | #274 |
Rock Crawler Join Date: Oct 2011 Location: Corona, CA
I've been thinking about running these axles on my Honcho. Other than the internals being different (and needing upper links for the 4link) is there anything else that needs to be done to make it compatible. Sorry if it's been asked before And are they wider than the Honcho axles? Last edited by Armistice; 01-21-2012 at 02:55 PM. |
02-09-2012, 04:00 PM | #275 | |
The Wraith axles are wider than the SCX10 axles. | |
03-02-2012, 08:29 AM | #276 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
Bender what drive shafts are you using on this? I have a rig with a 13" wb, 3 link with panhard up front but my rear shaft is long because it's offset like yours. My MIP's don't fit out back but easily fit up front with the 3 link. Any mip's a little longer then the scx version? I tried looking on the MIP site but they don't list measurements for all there shafts.
03-02-2012, 08:57 AM | #277 | |
03-02-2012, 09:31 AM | #278 |
Cool thanks man... I'm using the wraith shaft out back too but it's not getting as much engagement as I like so I gotta make it longer. But I'd much rather get an MIP for it... something tells me the wraith shaft won't last long with a tekin pro4 3300 kv on 4s lol
03-02-2012, 11:11 AM | #279 | |
06-10-2012, 07:37 PM | #280 |
Pebble Pounder Join Date: May 2012 Location: Satsuma
IM sure my truck is rather differnt then his because i didn't flip the mounts or stretch the rear. I'm running hot racing wraith links all the way around. Here is a picture of the width differnce between the stock scx-10 axle(front) and wraith axle(rear). ....and @bender- how long are the shocks your running and what are they? |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-scx-10/221956-benders-honcho-now-sporting-wraith-axles.html | ||||
Wroncho Action Shots | This thread | Refback | 10-05-2011 01:50 PM |
