04-03-2010, 09:26 AM | #1 |
| eric113's Honcho
This the start of the my honcho. Specs Scx-10 turned Honcho Handbros CMS kit Hitech 5645 Losi MRC servo for shift duty's Holmes WP TorqueMaster BR-XL JPH team checkpoint 19t motor 2 CC bec's 3racing winch rc4wd rox lox Msd 1.9 "rocksolid" wheels Jason's summit trans mount Honcho/SCX-10 Summit transmission mount. Summit trans Jason's maxx shaft mod Maxx Shafts made easy. Axial cvd's Axial heavy duty gears Axial 36/13t gear Axial 4 link mount All screws stainless Stainless steel links Big thanks goes out to Jason,Rockcrawler,BOWTIE thanks again guys! Last edited by eric113; 04-03-2010 at 09:28 AM. |
04-03-2010, 09:33 AM | #2 |
Ultimate RC Decals Join Date: Aug 2005 Location: San Antonio
nice E!!!! very clean shift linkage set up. very simple. you decide on paint yet? |
04-03-2010, 09:42 AM | #3 |
Quarry Creeper Join Date: May 2007 Location: Temecula, CA
You have a good parts list. I want to see how that Summit trans does on wheel speed. Keep up the good work!
04-03-2010, 10:01 AM | #4 |
Where did you get the rear 4 link bracket?
04-03-2010, 10:02 AM | #5 | |
The summit trans has the wheel speed, just pends on motor and gearing you go with. | |
04-03-2010, 10:03 AM | #6 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
I have Summit tranny envy..... You are going to love that JPH Checkpoint motor,I have a 23t on 3s and it is super smooth down low and rips when you pull the throttle.
04-03-2010, 10:06 AM | #7 |
04-03-2010, 10:22 AM | #8 |
That gets my stamp of DISAPPROVAL.
04-03-2010, 10:26 AM | #9 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
Sweet!
04-03-2010, 12:11 PM | #10 |
04-03-2010, 12:14 PM | #11 |
no, mine fits just inside the body. That's weird.
04-03-2010, 12:14 PM | #12 |
04-03-2010, 12:17 PM | #13 |
| That is using the stock location dimples on the bed. So my 2 options are 1. cut part of the mount where it clear 2. drill new holes for the bed mount and move it back so it clear Btw Jason... Your mount looks badass powered coated black. Last edited by eric113; 04-03-2010 at 12:20 PM. |
04-03-2010, 01:44 PM | #14 | |
| Quote: | |
04-03-2010, 08:41 PM | #15 |
Rock Crawler Join Date: Sep 2006 Location: Lititz
I would go with #1 since it doesn't look like you are using that part of the bracket. I have to give props to Jason, very nice design on the bracket. Really wanted to use it on my swap, but after scaling pictures I found it wouldn't fit under the Dingo body I like it with the 1.9 wheels What radio are you going to use? |
04-03-2010, 11:23 PM | #16 | |
For now, I'm use DX3R. Later on I will swap to Futaba 4pk. | |
04-04-2010, 06:19 AM | #17 |
I like the rok lox that you have on there now, I want to get a set of them soon. Also noticed that your not using the spring thingy on your shift linkage, I couldn't get mine to shift consistently with it so I rigged up a throttle type linkage. For a radio the 4pk is the stuff. If you want a cheaper route you can pick up a Traxxas 2.4, 4 channel on the bay for around $100. I had to mod it slightly to get the 3 position switch to work for the winch, very easy mod. |
04-04-2010, 08:06 AM | #18 |
RCC Addict Join Date: Sep 2008 Location: Mccalla,Al
You have got to cut that other servo mount off the front axle. Looks good Eric,I'll race ya at ECC. |
04-04-2010, 09:46 AM | #19 | ||
Let's see if I can get my truck done in time. | ||
04-06-2010, 07:31 PM | #20 |
is it done yet!?!?
