05-28-2010, 08:56 AM | #1 |
Rock Stacker Join Date: Mar 2010 Location: Whitefish Montana
| More front end assembly help needed...Honcho
I have the Honcho kit and I'm having difficulty getting the front steering together. I have installed Axial C-hubs, Axial Knuckles and Axial Competition Universal Drive-Shafts. I'm using a Hitech 645 to turn the lot. My problem is that in order to have the knuckles both squared-up and pointing the wheels straight I have had to lengthen both the drag-link and steering link. I have about an 1/8-1/16" exposed threads now on each end of the links. The other problem is the drag link is in contact with the front of the differential and won't allow much travel on the steering at all. I hope all that makes sense. I know somebody must of had this issue before. This 'custom' (all Axial parts) front end has been giving me lots of trouble and it's really slowing down my build. I'm tempted to put all the stock components in just so I can complete this thing and start having fun. Thanks guys. |
05-28-2010, 09:00 AM | #2 |
Got a picture? What servo horn?
05-28-2010, 09:42 AM | #3 |
You don't have to lengthen the steering link or the drag link if everything is done correctly. Please post pics.
05-28-2010, 09:52 AM | #4 |
OK guys, bear with me...I'm trying to get some pictures up right now. |
05-28-2010, 10:13 AM | #5 |
05-28-2010, 10:35 AM | #7 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
Looks like you are using the axial high clearance knuckles instead of the standard axial al knuckles and that is causing the problem.
05-28-2010, 10:42 AM | #8 |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
some of the problem could be that spacer on the steering, since you only have a spacer on one side the angle could lengthen the gap and and make the problem. also going back to the stock knuckles would help with the clearance issues you are having with the servo horn. i think that the knuckles are the source of most of your problems.
05-28-2010, 10:44 AM | #9 |
Thanks Texas. I thought about the knuckles being upside down and may give that a try. The instruction book shows the stock plastic pieces installed that way but the arms are more centered on the plastic piece so it's kind of hard to tell. My son has an SCX-10 TR that I compare stuff against and the arms are biased toward the top on his truck. Thanks again for the input.
05-28-2010, 10:46 AM | #10 |
I was wrong, they are right but are the high clearance knuckles which I did not catch at first. Try this thread here for some help: House's Bronco He is using the hand brothers steering kit but I think it will aid some of your issues. Also see badgers build here: My Axial SCX10 Trail Honcho, King of the Bean rebuild! Last edited by TexasSP; 05-28-2010 at 10:49 AM. |
05-28-2010, 10:54 AM | #11 | |
RCC Addict Join Date: Oct 2008 Location: PA
05-28-2010, 11:30 AM | #12 |
Thanks for the help guys. I'm pretty frustrated that the Axial parts aren't working. I bought all their parts specifically to avoid these types of issues. All of these parts are shown in the manual as optional parts yet they don't work together or the instructions are sufficiently grey as to not allow proper installation. I think I will contact Axial and see what they say.
05-28-2010, 11:41 AM | #13 |
Well the reason the High Clearance Knuckles require a longer rod is because of geometry. They were designed to have less Ackerman Angle at full steering. Once you figure it out, you'll love the difference |
05-28-2010, 11:43 AM | #14 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
You should probably be using these knuckles. http://www.rpphobby.com/product_p/ax30496.htm The arms are lower down like stock.. and they should bolt right in.. |
05-28-2010, 11:46 AM | #15 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
Arnt those knuckles for the axial BTA steering??
05-28-2010, 11:52 AM | #16 |
Well I hope so Gimp! I understand the geometry and the theory behind it (I think). I still find it hard to believe that more parts are needed to make this work. What is the longest rod Axial makes and why isn't it also shown as an optional part? Installing the Hand Bros kit ora longer rod isn't going to move the tie-rod away from the diff. That can only be done with more offset on the rod ends, longer knuckle arms or shaving/clearancing the diff. Am I wrong? I wrote Axial to see what they recommend. I'll pass on their thoughts when I hear from them. |
05-28-2010, 11:56 AM | #17 |
| Here's the part #of the knuckles: AX30526. You may be on to something here roksloski/Big B. I just looked at the manual and the optional part they list is AX30496. So much for getting this together for the weekend! |
05-28-2010, 12:10 PM | #18 | |
Just throw the stock plastic ones on for this weekend. They're stronger than you might think. | |
05-28-2010, 12:20 PM | #19 |
Great idea BigB!! I knew you guys could figure this out!! I just checked and the proper knuckles are 'out of stock' at RPP. I'm waiting to hear back from Corey. I still don't know how you could make these work on the front axle. I guess I could see them working in a BTA application though. Anybody want a good deal on them? |
05-28-2010, 12:44 PM | #20 | |
The knuckles aren't "made" for BTA, but yes they do come in Axial's BTA kit. | |
