Thread: high clearance links
Old 06-13-2010, 01:38 AM   #1
Default high clearance links
what links do I need for the bent four link for my honcho, and what do i need for the high steering? Also, what are some other recommended upgrade parts for durability? So far I am lovin my Honcho, just looking to get rid of the plastic links. It has FX-R 35t installed and some tires on the way. Anything else y'all would recommend?
Highboost73 is offline   Reply With Quote
Old 06-13-2010, 09:08 AM   #2
The bent links would be these:
http://www.rpphobby.com/SearchResult...ch=axial+angle
I believe they are 101mm and would have to be cut down slightly and re-tapped/threaded to work on the honcho.
For the high steering you need either the vanquish high steer knuckles or the axial high steer knuckles, and you will also want to go ahead and get aluminum c's while your at it. It takes some tweaking to work correctly on the scx from what I understand though. Do a search and you will find info.
Anyhing else, I would just drive it and see what you feel it needs or what breaks first. Usually the shafts pop off the yokes before anything else breaks at which point you want to at least upgrade to stampede half shafts or even better the MIP splined shafts. The next thing to go is usually the aluminum outputs on the transmission which are upgradeable to either axial steel outputs or the robinson racing spool. Then your next weakist link is the pinion and bevel gears in the axle at which point you upgrade to the axial hardened steel set.
TexasSP is offline   Reply With Quote
