06-23-2010, 04:36 PM | #1 |
Newbie Join Date: Jun 2010 Location: Winter Haven
| waterproofing
im thinking about gettin the scx10 kit but dont know what electronics to put in it i was thinking along the lines of waterproofing the whole thing what would be good elecronics to do that with
06-23-2010, 05:09 PM | #2 |
RCC Addict Join Date: Nov 2005 Location: Kansas
Well, for starters, this is in the wrong section. Then, it's also a common question, and the search button will give you plenty of results. But, I waterproofed my Honcho, so I'll help. I am still using the stock radio box, and put my receiver in a balloon and ziptied it closed before putting it in the box. I then put a bit of dielectric grease around the opening of the box, as a bit of added protection. I'm running a waterproof Traxxas XL-5 ESC (I highly recommend it...) so no worries there. I mounted it to the radio box in the stock location Nothing really needs to be done to the motor... Dielectric grease and electrical tape the battery connections, just for added protection. I still haven't completely figured out the servo. I have dielectric grease, but I wanna make sure I know what I'm doing before a servo gets fried. I'll just have to keep SEARCHing |
06-23-2010, 05:50 PM | #3 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
Do as said above. I used the TRX XL5 for a while but did not like that I was limited to 2s lipo, had no drag brake, and no lipo cutoff. I went with an FXR and have it sealed in a condom (a balloon works too). I sealed my receiver in the electronics box with clear silicon sealant. Have been fully submerged numerous times with no issues. May will say use the Traxxas 2075 servo but I suggest otherwise. The TRX servo has decent torque but they tend to burn up easily and strip gears. Hitec waterproofs almost ever single servo they make and that's what I use. You will also want to get seom grease in the axles and switch out the stock screws to stainless. |
06-23-2010, 05:55 PM | #4 |
Rock Crawler Join Date: Feb 2010 Location: Hayesville
I have a hard time fitting my rx in the box without smashing the plugs where they plug into the rx. I am using spectrum sr300.
06-23-2010, 06:47 PM | #5 |
Newbie Join Date: Jun 2009 Location: Colombia
i am using : ESC novak Rooster Servo Hitec HS-5645MG Slash waterproof box in the traxxas receiver box fits other receivers, so is a good solution works great so far |
06-23-2010, 07:08 PM | #6 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
I put everything into balloons, add zip tie, then a bunch of silicone then another zip tie, works really well, I drive a lot of my stuff like its a submarine and have never had a balloon leak. For servos I pack the gears with marine grease, and use silicone to seal the case, anywhere there is a seam or opening. |
06-24-2010, 03:48 AM | #7 |
Newbie Join Date: Feb 2010 Location: Melbourne Australia
I put my Rx and winch control in a waterproof electronics box,use a WP HK servo and was using a WP XL-5 but last week it lost reverse (full reverse gave full forward and partial reverse worked sometimes) it lasted 5 months,after some searching i found this is a common problem with these esc's Time for a HH torque master WP esc |
06-24-2010, 04:34 AM | #8 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
I pulled all my electronics apart and sprayed them with liquid tape. All the gears including the servos, were treated with green waterproof grease. So far I have not had any problems. Plus, if you go with the spray vs the dip the original cases can be used for the electronics. This avoids giant boxes taking up valuable space on your rig. Wes |
06-24-2010, 07:40 AM | #9 |
Rock Stacker Join Date: May 2010 Location: portland
+1 the Plasti-dip or liquid tape is great, I took my mamba max apart last year and waterproofed it, It was ran in my Slash for the winter now it is in my Honcho which only plays in the water |
06-24-2010, 08:04 AM | #10 |
| Ok so you just pull apart the case and spray liquid tape on the board, and seal the case with the liquid tape when your done.
06-24-2010, 08:58 AM | #11 |
and void your warranty too. Sealing it in a case/balloon/condom is a better option and is guaranteed not to damage any parts?
06-24-2010, 04:53 PM | #12 |
Rock Crawler Join Date: Apr 2010 Location: America
this is the way im plannin on doin it ima buy a traxxas 2wd slash and just use the electronics off of it and the reciver box the slash runs from 210-250 bucks and thats worth it to me becasue i get a 7-cell 3000mah battery and radio and reciver
06-25-2010, 12:04 AM | #13 | |
06-25-2010, 07:30 AM | #14 |
Rock Stacker Join Date: Jun 2010 Location: Jersey Shore
would i need to take all these waterproofing procautions if i just wanted to ride my honcho in snow? also what about on a beach? does all the wet sand effect anything at all?
06-25-2010, 08:05 AM | #15 |
I would at least take some precautions for the snow. Snow melts and the electronics get hot. As far as wet sand, that is an issue too as sand gets into everything, wet or not. It's always better to be safe than sorry. One drop of water in just the right spot can fry an ESC. Everything talked about is cheap. I have a total of about 1 dollar invested into my waterproofing so............1 dollar insurance for 50 dollars plus in electronics is a pretty good deal IMHO.
06-25-2010, 06:14 PM | #17 | |
Pebble Pounder Join Date: Nov 2009 Location: Kingsport, TN
Have any pics of how you mounted your box?? They were sold out of the 4x2x1 or I would've got it. | |
