![]() | #361 |
Rock Crawler Join Date: Mar 2013 Location: Waukesha
| ![]() I've heard allot of people leaving them stock for quite some time. There's been posts on here about people running them stock until something breaks. Then upgrading. Me personally i like to make it "My" truck so i've done a whole bunch of stuff to it before i've actually really driven the truck. I still have yet to really drive it hard enough to break anything but eventually it will and i'll upgrade that part. Most common thing i've seen is the plastic links replaced with metal ones due to unwanted flex but these trucks are very capable in stock form.
![]() | #362 |
Rock Crawler Join Date: May 2013 Location: Uniontown
Replace the weak Y-link mount with a shear mount of some sort, especially in the back. The kits come with the parts you need. Another freebie is mirror reverse the transmission to reduce torque twist. Sent from my XT1585 using Tapatalk |
![]() | #363 | |
Quarry Creeper Join Date: Oct 2012 Location: Malang, Indonesia
| ![]() Quote:
first of all, drive it stock for a while.. after you manage your rig, then look around where's the possible weak points then move up replacing:
![]() | #364 |
I wanna be Dave ![]() Join Date: Nov 2014 Location: West Texas
Carbon fiber is your friend. Remember think light! When your climbing rocks low center of gravity. 149 r/c worx's Team Driver |
![]() | #365 | |
Newbie Join Date: Dec 2016 Location: Socal
| ![]() Quote:
![]() | #366 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
Can somebody tell me if the scx10 chubs fit on the scx10ii please. I've searched till I'm blue in the face
![]() | #367 | |
| ![]() Quote:
Sent from my XT1585 using Tapatalk | |
![]() | #368 | |
Newbie ![]() Join Date: May 2015 Location: West Monroe
| ![]() Quote:
What did you make the brackets out of? It looks like carbon fiber!! | |
![]() | #369 |
Newbie Join Date: Mar 2017 Location: Moscow, Russia
Do bend rod ends (especially for upper links) make suspension articulate smoother or it doesn't matter and the straight ones no worse? Do traxxas metal balls fit the SCX10 mounts or are slighly bigger? Last edited by GTIgor; 03-10-2017 at 11:34 AM. |
![]() | #370 |
I lengthened mynypper links around 10mm ish so now the axle is tilted forward slightly reducing wear on the bearings and giving the prop shaft better clearance like the scx10ii
![]() | #371 | |
Newbie Join Date: Nov 2012 Location: Dallas
| ![]() Quote:
![]() they're primarily used to raise them up so they dont slide on rocks or get caught up on objects. The upper links are bent to clear other suspension components, like the lower links or angled-inwards shocks. However that may leave the propshaft more exposed and more prone to dragging on rocks. | |
![]() | #372 | |
| ![]() Quote:
![]() | #373 |
Quarry Creeper Join Date: Aug 2017 Location: KY
Traxxas TRX-4 bumper mounts work on the SCX-10. You need to file 1mm from each side where the mount slides into the chassis to get it to 70mm overall width. Other than that, perfect fit. The Axial bumpers slide into the TRX-4 mounts perfectly (even tho the holes are square). They can be flipped upside down to offer a lower or higher mounting position. Best thing is, they're only about $10 shipped for the front/rear mounts in a bag - whereas you have to buy an Axial bumper to just get the mount. I've got pics, I'll try and get them posted up tomorrow. ![]() ![]() The TRX4 bumper pins (right) are larger than the Axial pins (left) ![]() Last edited by number9; 11-07-2017 at 07:34 PM. |
![]() | #374 |
The best tip of all is to get rid of your axial honchos. I spent so much time and money replacing sloppy parts and it never performed anything more than mediocre. Living in the UK with hot and cold weather and a lot of wet mud didn't do it no favours either, since purchasing my hpi venture and TRX4 ( 6 months) I've replaced nothing other than 2 servos. My happiest axial moment was selling them. Both wraith and my scx.
![]() | #375 |
Rock Stacker Join Date: Oct 2016 Location: Us of a
Bought a completly dissasymbled truck in a box. when i put it back together by chance i mirrored the trans. burnt up 2 motors from running alot of negative timing before i did any research on motor direction! I if you buy a used truck pay attention to motor direction if your running a motor thats not set to 0° Sent from my SM-G955U using Tapatalk |
![]() | #376 | |
Newbie Join Date: Feb 2013 Location: BC Canada
| ![]() Quote:
For dingo wheel base use TRA5318 for both front and rear. For honcho wheel base use TRA5359 for the rears. You can use either jato rod ends or like I did and use TRA5133 rod end spacers to correct the pinion angle. The steel links help to add low weight and are relatively cheap compared to alloy, if you want to keep it light and spend more $ then opt for the alloy links of whatever flavor you prefer. Hope this helps. ![]() Last edited by Just 4 Fun; 03-03-2019 at 07:11 AM. Reason: added photo | |
