01-16-2011, 09:15 PM | #41 |
Rock Stacker Join Date: Jun 2007 Location: Layton
That ford is bad ass u just need to lower the body just a bit. If u want a lifted look do it the right way by doin the suspention. |
01-17-2011, 04:26 AM | #42 |
Rock Stacker Join Date: May 2010 Location: guam, usa
01-17-2011, 06:22 PM | #43 |
Rock Stacker Join Date: Dec 2010 Location: Pickens, SC
the main thing is to have good clearance for your tires. In other words, you dont want the body to sit too low.
01-21-2011, 10:51 AM | #44 |
Pebble Pounder Join Date: Sep 2010 Location: Calgary
Can't believe how good the tsl's are in the snow. Just need enough wheelspin to clear the treads just like the fullsize.
01-21-2011, 12:39 PM | #45 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
Awsome build! I am glad to see people are still suing the SCX10 kit I think I would throw up if saw yet another HONCHO build. Is it just me or does that truck look funny (Honcho) and there are way to many of them out there. I like the idea of building the kit then adding your own body so your truck doesn't look like everyone elses. Any ways I am rambeling. Sweet Build dude and props for making something that is your own and not a cookie cutter Honcho |
01-21-2011, 02:21 PM | #46 |
I'm totally with you on the honchos. They just look all the same. The great thing is that the wheelbase is close to most other r/c models so they can all be used with a bit of work.
01-21-2011, 06:37 PM | #47 | |
Check it out if you like http://www.rccrawler.com/forum/showt...83#post2876183 Last edited by Grumpster1980; 01-21-2011 at 07:02 PM. | |
01-26-2011, 12:13 PM | #48 |
My next project for it is installing the 3racing led lights. I haven't test the theory yet but the plan is to traced the outside light decals and mask the inside, then clean the paint off behind each decal and install the led inside. The idea is that the light will glow through the decal, plus the imperfect paint edges will be hidden behind the decal. If you can visualize both the tail and side marker light glowing, 50% and 100% under full braking. |
01-26-2011, 12:14 PM | #49 |
Just need to test how much led light glows through the decals.
02-03-2011, 09:39 AM | #50 |
02-03-2011, 12:44 PM | #51 |
Quarry Creeper Join Date: Nov 2010 Location: weeki Wachee
heres my scx10 with a new bright '11 f-150 crewcab cut down to an ext cab. to eliminae the body lift cut some aluminum to fit on the stock suspension posts then drill some holes at the bottom of the the alum. to raise the chassis. my rear shocks are in the stock location but i like the squat look |
02-03-2011, 01:11 PM | #52 |
Rock Stacker Join Date: Oct 2009 Location: santiago, Chile
02-03-2011, 01:59 PM | #53 | |
02-03-2011, 02:01 PM | #54 | |
How'd you get your wheels to clear the body width? Use spacers or just wheel offset? | |
02-03-2011, 02:35 PM | #55 |
02-09-2011, 05:44 PM | #56 |
Some snow pics with the new shoes. Still need to do the lights. |
02-11-2011, 12:15 AM | #57 |
Pebble Pounder Join Date: Feb 2010 Location: Sterling Heights
| FORD RAPTOR body on SCX10 Honcho - Jconcepts 0084
Well, after another RCC member (thanks Kujo) showed me his build on Scale4x4rc.org using the Jconcepts Raptor for the Revo body, he advised methat the Jconcepts Slash 2wd (aka #0084) would fit almost exactly on the Honcho. So, I ordered up a body and he was right. It should turn out nicely. Here are some pics to show how it fits on the Honcho. The #0084 wheelbase is around 12 inches, about 19.25 long, and about 8.5 wide at the fenders. The body is just placed on the posts right now, I would like it to sit a tad lower to be more scale looking. Hope this helps anybody that was wondering what would fit. |
02-11-2011, 12:09 PM | #58 | |
12-27-2011, 02:50 PM | #59 |
Newbie Join Date: Dec 2011 Location: Surrey
| Re: Ford Scx10 crew signing in
Does anyone know if the 1973 blazer body from proline will work on the honcho?
12-27-2011, 02:51 PM | #60 |
Sorry 1980
