07-27-2010, 08:24 PM | #1 |
Quarry Creeper Join Date: May 2010 Location: trinity
| waterproofing axles on the scx10
hello everyone i am thinking about putting waterproof electronics on my scx and want to know how to waterproof my axles cause i know if i run in water they will rust solid shut and want to know what to do to prevent this from happening thanks yall zachary flowe
07-27-2010, 08:26 PM | #2 |
pack them with a thick grease.
07-27-2010, 10:50 PM | #3 |
put gurb secrew or short screw in the holes on top the the axles
07-28-2010, 01:18 AM | #4 | |
Pebble Pounder Join Date: May 2010 Location: brisbane australia
water will still get in someway or another.. I packed mine with marine bearing grease from supercheap auto..$10 Fully packed it that if you shut the diff grease will squirt out thats how full it was..been running it for over 3months now still works sweet | |
07-28-2010, 08:04 AM | #5 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
All of the above answers will help with keeping water out, but it will still find its way in thru the pinion and axle bearings. Ask me how I know |
07-28-2010, 08:11 AM | #6 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
| This is what I did to mine. I used bearing grease from Lowes. Works very well and actually keeps water completely out. Of course my issue was dirt and debris more than water, but this works well for both. The outer grease next to the straight axle adapters and c's get's very dirty but the inner stays clean and dry. Have had this setup for a couple of months now with great success. It also keeps the bearings from getting corroded and locking up.
07-28-2010, 06:04 PM | #7 |
thanks guys ill give some of those a try and let yall know wich one works thanks zachary flowe
07-30-2010, 11:00 AM | #8 |
Rock Crawler Join Date: Jun 2010 Location: UTAH COUNTY
how do you guys think dielectric grease would work for lubing up the axles??
07-30-2010, 11:15 AM | #9 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
As others have said it will work but keep in mind you will get some water inside so you might want to check for rust.
07-30-2010, 11:19 AM | #10 |
| im going to be putting new overdrive gears in the front axle today so if the gears are a little rusty thats cool they'll be coming out anyways. thanks for the input.
07-31-2010, 09:47 AM | #11 |
Rock Stacker Join Date: Aug 2008 Location: granada hills
well what i used is redline marine grease! is supposed to be water proof or something. i packed the diffs so when i closed the diff up it shot out of every crevis. then use the set screws the same ones from the pinion gears. for all 4 holes on both axels either way you will rust the bearings.. |
08-10-2010, 11:30 AM | #12 |
Rock Stacker Join Date: Aug 2010 Location: Minneola, Florida
you can use dielectric grease thats what I use
04-03-2011, 07:29 PM | #13 |
Newbie Join Date: Dec 2010 Location: united states
THANK YOU!!!!! ive been wandering what to do so today i filled them with grim racer marine grease....
04-04-2011, 10:28 PM | #14 |
Newbie Join Date: Mar 2011 Location: anywhere my two feet are standin.
i been wonderin about the axles for a while know thanks know i now wut to do |
04-04-2011, 10:41 PM | #15 |
Newbie Join Date: Mar 2011 Location: St.Clairsville
I have also been wondering about this topic but i have been afraid to ask but now i know thanks for the info !
