01-13-2011, 05:15 PM | #1 |
Newbie Join Date: Aug 2009 Location: Netherlands
| SCX10 TR - how to control stock led lights controller via 4CH TX
Hi, I have SCX10-TR. I use a Futaba 4PL 4CH radio and the 4CH S-FHSS receiver that came with the TX. I have connected the LED controller wire to CH3 on the receiver. But If I switch CH3 on / off from the TX it doesnt affect the LEDs. LEDs are always on or always off based on the fact that if the ESC is on or off. I can't seem to control it via the TX. Can anyone help me accomplish this please ? |
01-13-2011, 05:25 PM | #2 |
Rock Stacker Join Date: Dec 2010 Location: USA, OH, Columbus
You need a RX controlled on/off switch to do that. I am not sure how the TR version does it, are they always on or off? You need something like this: http://www.hobbyking.com/hobbyking/s...idProduct=8833 Rod |
01-13-2011, 05:30 PM | #3 | |
yes its always on or off... like if i switch on the kit i.e. switch on the ESC... the lights turn on... and they will go off only when i switch off the ESC... even though the controler is connected to CH3 in receiver.... Quote:
01-13-2011, 05:36 PM | #4 |
Okay, so if you want to switch them on/off from the TX you will need that switch that I posted.
01-13-2011, 05:42 PM | #5 | |
Pebble Pounder Join Date: May 2005 Location: Long Island NY
You could also go this route, and its a little cheaper http://www.dimensionengineering.com/PicoSwitch.htm | |
01-13-2011, 05:53 PM | #6 | |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
01-13-2011, 06:42 PM | #7 |
Rock Stacker Join Date: Jan 2011 Location: little mountain, SC
01-13-2011, 06:53 PM | #8 |
I overlooked the price of the actual unit only thing with HobbyKing is shipping time..
01-13-2011, 07:11 PM | #9 |
Pebble Pounder Join Date: Dec 2007 Location: CA
HAve you set your 3ch to 2 position? Then you also may have to set your EPA for 3ch to maximum number ( in my case with 3PKs is 120% ) Then it should be ok to control on/off via TX. |
01-13-2011, 08:03 PM | #10 |
Newbie Join Date: Dec 2010 Location: Fredericksburg/Spotsy
This will help you out. 3rd channel led light wiring |
