02-14-2011, 12:27 AM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Moses Lake
| Rc4wd oem wheels
Just got set of rc4wd oem steel wheels for a bronco build I am doing. The problem I am having is I can not get the lip of the tire to fit inside the inner ring. I am using flatirons and seems that the lip is to thick so it makes it damn near impossible to get fuses seat right. What am I missing or do I need to get a diffent tire to work these wheels?
02-14-2011, 12:37 AM | #2 |
Rock Stacker Join Date: Jun 2007 Location: Layton
Those rims dont work well with anything but rc4wd tires. If u look at the bead on rc4wds tires they are real thin unlike the flat irons that are thick. The flat irons will work but its a pain in the butt and alot of work. hope this help.. |
02-14-2011, 12:40 AM | #3 |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
you can also try cutting new inner rins from a 2 inch pvc pipe. the inner ring on the oem rims are exactly 1.9 inches, which means it barely fits the bead.
02-14-2011, 12:48 AM | #4 |
Thanks for tips. I was wondering about pvc pipe so i am glad u mentioned that. maybe i will give that a try. Thanks again.
02-14-2011, 11:20 AM | #5 |
Quarry Creeper Join Date: Jan 2011 Location: Kyle TX
Mr Layton is correct. Those rims don't like Proline tires. RC4WD even has a little note at the bottom of the description saying just that. Even RC4WD tires are hard to mount. The tutorial at the link they provide works pretty well but I never got it in 5 min. Good luck and post your solution when you get them mounted. |
02-15-2011, 02:06 AM | #6 |
So I tried some 2in abs and it seemed to work alright. After many curse words I think I got it to work for now until I can get some new tires. Thanks for the help.
02-23-2011, 10:30 PM | #7 |
Rock Crawler Join Date: Oct 2010 Location: Reno
I was looking for some answers about these wheels before I buy. Anyone know if they will work with 1.9 rovers on a MRC?
