03-10-2011, 11:11 AM | #1 |
Newbie Join Date: Mar 2011 Location: Denver
| Shock Questions
Sorry if this has been asked, but which shocks are going to provide me with some decent travel. I see you guys postin pics up on pop cans and such and it seems like you have way more travel than i do? any reccomendations? Are you guys runnin 95mm? 110mm? |
03-10-2011, 11:42 AM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: San Diego
your 95mm to 110mm thats the shock overall length what you really want is the shock's actual travel length. I know that the Proline PowerStroke has a shorter travel length than the stock shocks, I've mixed and matched Proline up front and stock in rear that combo has got my honcho over a 7-Up can. I would first try getting rid of your bump stop and take out some oil and see if you like your articulation.
03-10-2011, 11:50 AM | #3 | |
Newbie Join Date: Feb 2011 Location: Kearns
03-10-2011, 11:52 AM | #4 |
RCC Addict Join Date: Dec 2010 Location: middle,tn
with proper set-up the stock axial shocks can get u up on a pop can,first remove that piece of rubber on the shock rod its a stop so the shock dont bottom out that will give u a little more flex and its only good for shocks that racers use for big jumps or dropping ur truck off a building no need to have em while crawling, next get u some softer springs the red axial springs are the softest you would be surprise how much flex u will get by doing these two things, you can also put light shock oil in or pour some of the oil out like a half of shock body worth do these things and see where your at, i bet you'll b amazed |
03-10-2011, 11:53 AM | #5 |
| you can remove the rod end by holding the shock rod with some tapped up needle nose you dont want to scar ur shock tube or you can just cut it out you'll never need it again anyway its not needed for crawling |
03-10-2011, 11:58 AM | #6 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
| unscrew the bottom of the shock from the axle, push up (compress) the spring and take it off, pull off the spring retainer, unscrew the rod end, pull off rubber bump stop, put rod end back on, then spring retainer then spring then screw the shock back onto axle.. thats it.. or you can cut them, but i'd do it this way so you can save them.
03-10-2011, 01:03 PM | #7 |
03-10-2011, 03:52 PM | #8 | |
03-10-2011, 04:02 PM | #9 | |
03-10-2011, 06:39 PM | #10 |
| no springs? I think you are looking at shocks with internal springs or suspension set up that uses leaf springs. The purpose of the shock is to dampen the spring oscillations during suspension cycle, and the springs insures that the shock returns to its original length. I would toy with the stock suspension and see what you want out of your rig. Try experimenting with different preloads on your springs and also your shock oil. PM me and let me know how it turns out. |
03-10-2011, 08:29 PM | #11 | |
05-11-2011, 05:18 PM | #12 |
Newbie Join Date: May 2011 Location: Wausau
does any one know what shock oil weight is in the stock shocks
05-11-2011, 06:36 PM | #13 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
05-11-2011, 06:58 PM | #14 | |
Rock Stacker Join Date: Oct 2005 Location: Forest Hill
