03-25-2011, 11:07 AM | #1 |
Quarry Creeper Join Date: Sep 2010 Location: Gilbert, Az
| SLIPPER CLUTCH ???s
hi, i am attempting to build a scx10 & i am in the middle of the tranny/clutch portion & i have a question. i want to know "how" you install the pin that goes into the shaft that the slipper clutch goes onto? the pin (2 pins) came in the slipper clutch package & i am able to get it into the location hole but i do not know "how" to keep it in place (from falling out)? i am new to all this & don't know all the cool tricks & tips that you "seasoned veterans" have learned! thanks!! rc dreemer |
03-25-2011, 11:23 AM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: San Diego
There a sleeve/spacer that should go over it. The manual is available for download on Axial.com Good luck! |
03-25-2011, 11:24 AM | #3 |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
It is held in by magic! Actually once the assembly is complete, it can't fall out. Just keep it in place till the Spur gear (AX3062)and Slipper (AX30411,AX30410 slipper outer and inner) are installed. If it is being difficult falling out, then try a little grease on it (the pin). That will keep it in place till the gear and Slipper are put on.
03-25-2011, 12:03 PM | #4 |
js412, yea i finally saw the sleeve (which i do not have-think), but the picture makes me wonder what the whole thing is there for???. if the sleeve holds it in then why even have it? thanks!! |
03-25-2011, 12:05 PM | #5 |
rook, i will try the grease method (didn't think about that one!!) but i am nowwonderng what it iseven there for? thanks!! |
