05-23-2011, 11:24 AM | #21 |
if the pin groove was too deep there would be no play? You're making no sense, unless we're talking about two different things. I just did one of these the other day so I know it works. I mirrored a tranny and when I put it back together I did this just for the heck of it. |
05-23-2011, 01:05 PM | #22 | |
Quarry Creeper Join Date: Feb 2011 Location: Austin
The top gear is sandwiched between two bearings. If the groove was only as deep as the diameter of the pin then the shaft wouldn't move. But because the groove is 2-3x deeper, it allows the shaft/pin to move between the bottom of the groove and the bearing. Same thing applies to the pinion in the axle. Try it, you will see. Quote:
05-23-2011, 03:05 PM | #23 | |||
05-23-2011, 03:29 PM | #24 |
Just got a response back from Axial. They said this is normal and will not affect performance. I don't know about normal since I have never owned another RC with any play in the spur, but oh well.
05-23-2011, 03:35 PM | #25 |
| LOL, normal for them. I've been building RC kits for years and never had one wtih this much slop in the input shaft...LOL> |
05-23-2011, 04:20 PM | #26 |
Rock Crawler Join Date: Jan 2011 Location: Okanagan
its normal = room for grease, = grease it up and its resistant from mud and dirt
05-23-2011, 05:54 PM | #27 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
You did remember to put part # AX30499 on the spur gear shaft before adding spur assembly, correct? I only ask because in my haste to throw a tranny together a bit ago i forgot this pc. And i had exactly the same amount of slop your vid shows. Now its mayb a 1/32" of play with correct pc installed. Just a thought |
05-23-2011, 05:55 PM | #28 | |
05-24-2011, 05:39 PM | #29 |
Mine was almost as bad as the vid, with the correct parts installed. I ran it for a couple packs and didn't like how loud it was. Now that it is shimmed the thing is much quieter. It just sounds like a more quality assembly. I assembled an AX-10 a year ago and it's transmission didn't need any shims on the input shaft, but did require one on the output shaft. |
05-26-2011, 05:05 AM | #30 |
Pebble Pounder Join Date: Apr 2011 Location: Madison
| lateral play in the output shaft
There is no technical merit in having that much lateral play in the shaft. 1/16" of an inch play might be "normal" in terms of how the parts are tooled, but it is not good. |
