12-19-2011, 11:32 PM | #81 |
| Re: Natedog's Honcho kit build
Rear shock towers trimmed up. |
12-23-2011, 01:09 PM | #82 |
Crawled yesterday to test it out and works even better than before, slightly lower cog helps. Put the stock X brace back in the bed cage, it just looks better to me. On to the pics! Last edited by Natedog; 12-23-2011 at 01:37 PM. |
12-23-2011, 01:10 PM | #83 |
| Re: Natedog's Honcho kit build |
12-23-2011, 01:15 PM | #84 |
Pebble Pounder Join Date: Oct 2005 Location: Sacramento
Nice pics Does work well and thanks for trusting me to give it a spin |
12-23-2011, 01:20 PM | #85 |
12-23-2011, 01:22 PM | #86 |
You gotta stop letting me drive your gofast stuff....lol! Brushless Savage was insane fun. Oops...I bought a Wraith! Can't decide how fast/slow a motor I need with my 3s for it though. |
12-23-2011, 01:31 PM | #87 |
Gotta say I was grinning ear to ear on that run that new lipo shocked me and I have driven this beast before lol. Gotta get a beach run planned asap!
01-18-2012, 12:53 PM | #88 |
| Re: Natedog's Honcho kit build Yes the tires are on the rock...made the sidehill. Cut up kit Flat Irons with stock foams and a little weight. Last edited by Natedog; 01-18-2012 at 12:56 PM. |
02-08-2012, 10:50 AM | #89 |
Stock aluminum front lower links are becoming self bent high clearance links after the last outing, need to get something stronger in there!
02-19-2012, 09:47 PM | #90 |
Went out to Folsom Lake today and had a great time, stayed for hours! Forgot my dang batteries and luckily a friend loaned me a hardcase 5200mah 2s lipo which lasted the whole 4 hours! It definitely wheels alot better on sidehills and steep climbs with 1300mah 3s due to the weight and more wheelspeed. |
02-19-2012, 09:52 PM | #91 |
lol didnt know you were gonna use this shot! What are you doing in the back there? LMAO I got alot better ones just have to send em...
02-20-2012, 12:18 AM | #92 |
I wasn't but then laughed and had to...lol. I see what you mean your camera is starting to bite the dust I think. Thanks for the great pics, how did the video turn out?
03-21-2012, 01:51 AM | #93 |
Few more from our little trail ride Last edited by Natedog; 01-15-2013 at 12:32 AM. |
03-21-2012, 01:54 AM | #94 |
| Re: Natedog's Honcho kit build Something chewed on a deer and somebody's camera was on it's last leg... Last edited by Natedog; 12-22-2012 at 06:39 PM. |
12-22-2012, 03:14 AM | #95 |
Time for Honcho revamp! I don't like how the cab looks so wide and bulky any suggestions for a good body? I've been looking at sectioning out 35mm at rear of cab to make it a standard cab and sliding the bed forward the same amount but not sure. Also the rear bed brace would be right in line with the rear axle and rubbing the tire during flex. Heat gun might fix that. I want to run high steer knuckles and have been looking at the VP 8 degree knuckles and chubs, can I run them with the servo on the axle? How much of a widener would I need to clear stock Axial Honcho beadlocks? I'd like to keep any spacers to a minimum. |
12-27-2012, 01:55 AM | #96 |
Cuttin up the bed, going to do the rear like a rollbar with a down tube each side from the front main hoop to the bed side tubes. Like on my Wraith here: Natedog's Wraith Kit Build now with Cage Mods Playing with spare parts, bumper ideas Trying to get my high-steer setup with all Axial clockable aluminum c-hubs and highsteer knuckles. |
12-27-2012, 02:21 AM | #97 |
I didn't buy the VP high steer setup for my Honcho, but I'm still having some trouble with my Axial setup since the steering arms are shorter than the stock arms and the tie-rod hits the front of the axle housing too soon to get really good steering even with CVDs. Also seems the tie-rod must go under the arms or I can't run axle mounted servo?
12-31-2012, 12:23 AM | #98 |
Little cage mods tonight, lost 22 grams off the top of the cage and I like the look much better. Spacers to go in top main hoop holes Making new down tubes Top of downtubes mounted, marked and ready to drill lower holes in outer bed hoop. Upper mounts used some Axial 3x30mm flat head self-tapping screws and cut them down to 25mm. Little heat gun action and new tubes bent and screwed together. Lower end of tubes attached with Axial 3x18 buttonhead self-tappers. That's the bed mods for now, going to test and then may bob about 18mm off the rear lower part of bed. Need to get my Axial hi-steer setup worked out, anybody got pics of how their's worked out, tie-rod length etc? Last edited by Natedog; 01-01-2013 at 11:15 PM. |
12-31-2012, 07:53 AM | #99 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
I like the new flat bed! hey... did you notice your cat didn't look too happy with you?
01-01-2013, 04:11 AM | #100 | |
| Re: Natedog's Honcho kit build Quote:
Nobody with pics of high steer with Ackerman? Got my steering figured and working tits! Little but of grinding and it'll be sooper tits! Pics later. Happy new year everybody! Last edited by Natedog; 01-03-2013 at 03:14 PM. | |
