Thread: Can i buy just the links without full set to fit my cherokee proline 1992?
Old 07-19-2011, 07:15 PM   #1
Default Can i buy just the links without full set to fit my cherokee proline 1992?
i need shorter links to start painting my body
it's a cherokee 1992 proline
Can i just buy the rear shorter links?
my kit is the scx10 honcho (KIT VERSION) with metal links
sebastien^_^ is offline   Reply With Quote
Old 07-19-2011, 07:43 PM   #2
yes most hobby stores carry them look.
JS412 is offline   Reply With Quote
Old 07-19-2011, 08:09 PM   #3
I just dont want to pay 50$ for the set...
do they sale only the rear ones? got a part #?
Old 07-19-2011, 09:05 PM   #4
It's just as easy to make them as it is to buy them, also cheaper too.
Traxxas Revo rod ends (#5347), 8-32 all thread, 1/4" fuel line or aluminum tube to cover the all thread. All you need to do is measure how long you need them and just cut the all thread to the correct length.
canadianbacon is offline   Reply With Quote
Old 07-19-2011, 09:55 PM   #5
thanks fellow canadian :P ill post it on our forum
but do you have the genuine part of axial ?
all i can find is a set for around 50$... wich is bleh too much :P
Old 07-19-2011, 10:09 PM   #6
This what you are looking for?
91mm:
http://www.rpphobby.com/product_p/ax30524.htm
You can look through that site and find all kind of options for links. The base scx10 came with these in the front and rear to make an 11.4 wheelbase. So with the 98mm fronts, and these in the rear it should be about perfect for a Cherokees 11.8 wheelbase.
Rook82 is offline   Reply With Quote
Old 07-19-2011, 10:50 PM   #7
thanks rook this is exactly what i needed
but don't i need just 1 set for the rear this is what i hear
before i make a order i want to make sure
Old 07-19-2011, 11:22 PM   #8
when u change one set of link you'll prob want to change the other depending on your axle angle. I tend to try and get my axle angle as close to zero as possible in reference to the drive shaft out put.
Old 07-19-2011, 11:37 PM   #9
Scale Detail Engineering
canadianbacon ftw!
You can do it... make them, you'll thank us.
johnnyh66 is offline   Reply With Quote
Old 07-20-2011, 12:44 AM   #10
Use traxxas part 5318. It's the revo push rods. You have to twist one of the ends to make the ends the same direction. I just did this for my Cherokee build. It does not completely center the rear but it's only off like 2-3 mm.
whjdm069 is offline   Reply With Quote
