11-18-2011, 01:06 AM | #1 |
Quarry Creeper Join Date: Oct 2011 Location: Reno
| Sh!tlbuffout SCX-10 JK Build
so i bought this SCX-10 about a month ago. it's been a bunch of work so i think it's time i make a build thread on it Specs: Tekin FXR ESC 35t Novak Rockstar motor 3s Lipos 1.9 Rox loks 452 Oz. Futuba Servo Castle 10 amp BEC 6 channel Rx & TX futuba 87 tooth Spur Gear 14 tooth motor gear 3:1 axle gear ratio tons of aluminum upgrades here's what i got as after tons of work i normal use 1.9 wheels but i slapped on some 2.2 to see what it could do |
11-18-2011, 01:09 AM | #2 |
i have snow chains too i made some tow ropes and i tried making my own foam (it worked out pretty good. did all 4 tires for 4 bucks) OLD Foam NEW FOAM |
11-18-2011, 01:10 AM | #3 |
RCC Addict Join Date: May 2011 Location: Utah County
wow that tube work looks fantastic! i love the front bumper! got any pics without the body? edit: LOOKS way better on 1.9's too btw. i'm sure the 2.2's perform, but those 1.9's just.. fit.. you know? |
11-18-2011, 01:16 AM | #4 | |
ya i'm uploading pics right now but right now i have a new jeep body (New Bright JK Hard body) i'm working on doing tube work for it i got everything cut and bent and next is welding everything together | |
11-18-2011, 01:35 AM | #5 |
here's it at it's first G6 Challenge had technical difficulties all day HERE"S IT WITH A TRUE CHAMP Dan Wilson |
11-18-2011, 01:37 AM | #6 |
here's the new body after some body work and some paint and lights and new electrons running like a champ now Last edited by ZackMicF; 11-18-2011 at 02:17 AM. |
11-18-2011, 01:46 AM | #7 |
then i took off the fender flairs because they kept breaking off and i got tired of glueing them back on then i decided it needs some tube work done to it. so i went out and bought some 3/16 brake line but i needed a bender because my vise like to kink tubing soooooo i just made one instead it's got 20 bolt holes and it took me almost 3 hours to drill and tap all of them. it's made out of a 1/4" steal plate it fits 4 different bolt sizes 1/4, 5/16, 3,8 and 1/2 and i found a bunch of bolts, washer and stuff in my garage to help with the bends here it is (don't steal my idea and go sell it. i took a lot of thinking and time to make this and i didn't copy anyones idea, so go create your own. it's super easy!!!) but the holes all in different spot to get different bend so so i do have to move it out of the vise. it's super easy to use too!!!! i made it so many extra bolt holes so i can put all my bolts and washer in it so when i put it in my tool box i don't loose any parts for it here's some pics Last edited by ZackMicF; 11-18-2011 at 01:49 AM. |
11-18-2011, 01:51 AM | #8 |
i made this tool box out of sheet metal to hold all my tools it works pretty good too i put all my LiPo batteries in it too incase the decide to blow up or some thing |
11-18-2011, 01:57 AM | #9 |
okay time to get back to the build now that i have all my tools situated i started on some tube work. now with my new fancy bender i did all this fancy bending in about 2 hours. now it's ready to be welding BEFORE ROCKSLIDERS FRONT BUMPER AND WHEEL WELLS REAR WHEEL WELL FRONT WHEEL WELL FRONT BUMPER THEN EVERYTHING LAID OUT |
11-18-2011, 02:10 AM | #10 |
here's a link to Video i made with the First JK body Axial SCX-10 10/29/11 - YouTube i got board one day and started digging a ditch to play in and it turned into a tunnel with rock crawling on top of it |
11-18-2011, 10:07 AM | #11 |
Quarry Creeper Join Date: May 2011 Location: Japan
This looks so fawking good. I love the JK bodies. Good job mate, cant wait to see it all built up! |
11-18-2011, 11:13 AM | #12 |
Newbie Join Date: Sep 2011 Location: Lake village
Subscribed you do awsome work man looks great!!!
11-18-2011, 11:31 AM | #13 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
Looks sweet, and awesome way of coming up with a tube bender.
11-18-2011, 12:59 PM | #14 |
11-19-2011, 03:02 AM | #15 |
so today i didn't get to weld anything up but i did a total rebuild on it and i took a bunch of pics when i put it back together so you guys can see my setup. i think that my SCX-10 has the best flex out of all them. it's because of one little secret i replace ALL the tie rod ends with Traxxas ones with the little metal ball in them i didn't put my Novak Motor back in because it snow all today so i put in a 20 turn so i can do a little drifting and play around and i have all my electronics in the box so when i want to go play in the water i just silicone the box shut and BOOM she's 100% water proof works pretty good too to start off i grinded a little section off the chassis because my servo kept hitting when i would go to flex. BEFORE Grinded FRESH PAINT (Flat black) AFTER |
11-19-2011, 03:05 AM | #16 |
Now to put it all back together ya i did swap my transmission around for less torque twist Shock Mounts, cross members and electrical box Rear Axle |
11-19-2011, 03:09 AM | #17 |
i put silicone around my servo to help keep the water out. it work pretty good too (the reason it's orange is because all i had laying around was high temp silicone) Then Front Axle. Then i even put some of those Traxxas tie rod bearings in the stock shocks too. it made a huge improvement because they always had a slight bind in them when the would move up and down. so i put that black spacer in too and now the breath a whole lot better |
11-19-2011, 03:13 AM | #18 |
Then Some WHEELS!! Here's my electronic box that i put all my stuff in. it's a tight fit but it work perfect then i put the lid on it and bolt it down then pop some zip ties here and there battery tray |
11-19-2011, 03:18 AM | #19 |
over head look Of Course some posser shot it can almost flex a Full 90* which is crazy for a SCX-10 all the pics i see they're maxed out on 3 tires i'm on a soda can and a Tire, their 7" tall so it works and all my tires are touching the ground!!!! |
11-19-2011, 04:17 AM | #20 |
Rock Stacker Join Date: Jan 2011 Location: Oak View,Southern California, Ventura County~805~
in the description of your video u mentioned you used your iphone.. how did u mount your phone there?? ive been trying to tape/ziptie my phone all over my jeep and no luck on it looking good or staying put, screen being accessible...etc.
