12-08-2011, 07:28 AM | #1 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
| Over or underdrive?
I'm thinking of changing gear ratios in one axle. If you were going to do one axle only which one is better bang for the buck? Is only doing one axle worth it, i.e. is the gain noticable? Would either one affect the run time dramatically? If the front is overdriven, is the wheel speed different enough that the pinion gear needs changes to regain the low speed? I will be adding high clearance knuckles, aluminum C-hubs, and CVDs to the front axle, and a set of beef tubes if I can find some. |
12-08-2011, 07:31 AM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Up North
Overdrive for sure.
12-08-2011, 07:36 AM | #3 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
I have ran the over drive with much sucess. I am trying the hd front underdrive rear in my wraith. We will see
12-08-2011, 07:36 AM | #4 |
Quarry Creeper Join Date: Jun 2010 Location: Wheeling
overdriving the front will help with better steering from it not pushing so bad, but the underdrive has more of a speed changing ratio compared to OD. I recommend both in a sportsman rig, you have to get used to it but you won't want to go back! scalers, well, hell I dont even change the r&p but I might later on down the road. |
12-08-2011, 07:43 AM | #5 |
I also noticed that with the OD that my turning radius increased(tighter).
12-08-2011, 02:56 PM | #6 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
if you can afford it do both, overdrive front underdrive rear... but if i can only afford one at a time i say overdrive the front. i was crawling with a guy 3 weekends ago that had a heavily modded/blinged out ax10 with OD/UD gears and it was ridiculous how tight the turning radius was. by overdriving the front if your on flat ground and there is 1 small rock by its self and you rest 1 rear tire behind the rock (like your going to drive over it) and give the throttle a few blips the front end will spin around like you have a dig. your front tires will spin faster than the rear and will with crawling. |
12-08-2011, 03:01 PM | #7 |
The reason I don't want to do both is I'm not sure what it would drive like on a trail in between obstacles. Maybe I'll do the front for now and see how I like it and then later underdrive the rear. We do a lot of scaling on hiking trails so there is some driving on pretty easy terrain and I don't want to be dragging the rear tires along the whole time.
12-08-2011, 04:41 PM | #8 | |
so overdrive the front and try it out, even on flat ground and you ease into the throttle the front will start turning and then the rears. if you want a tight turn blip the throttle and spin the front tires in the direction you want to go. im supposed to be crawling this weekend at a friends house (and hopefully picking up my ax10 that i ordered) and if the guy with the modded/blingy ax10 is there i'll get some video of his run because OD/UD makes a big difference!! | |
12-08-2011, 05:14 PM | #9 |
Quarry Creeper Join Date: Sep 2010 Location: Perth Australia
Ive been kooking at doing both on my rig but ive found it very hard to get the Axial 36/14T Overdrive gears (AX30401) anywhere everybody is out of stock.. So im going to keep the normal ratio 38/13 gears in the front and ive purchased the Axial 43T/13 underdrive gears (AX30402) for the rear axle. This gives both an overdrive effect (for more steering) as well as puts more overall gear reduction in the axles (reducing chassis torque twist). |
12-08-2011, 05:36 PM | #10 | |
Quarry Creeper Join Date: Jul 2011 Location: Seattle
12-08-2011, 07:10 PM | #11 |
Yeah I was looking around and couldn't find the overdrive gear anywhere. I wonder if Axial discontinued that too I may do the underdrive or just leave it alone for awhile... it's not broke yet... |
12-08-2011, 08:58 PM | #12 |
Quarry Creeper Join Date: Sep 2010 Location: too close to LRC.... Jealous????
my scaler is overdriven in the front and underdriven in the rear and it works great.... It climbs well, and turns better as well.....
12-08-2011, 10:38 PM | #13 |
Od front/stock rear= least numerical gearing difference Stock front/ud rear= middle of the road Od front/ud rear= most numerical difference Right now I'm running stock front/ud rear in some ar60's. I'm liking the turning radius, tt isn't horrible. |
12-09-2011, 01:09 AM | #14 |
Quarry Creeper Join Date: Jan 2011 Location: armstrong
I have recently changed the rear R/P to the under drive and love it. I already had the over drives in the front I recommend doing both is will help with step climb and descents as the rear tires are going to not want to dig in as much on climbs and with descents it will drag a little more making your rig more stable, also turning radius becomes even tighter
12-09-2011, 01:35 AM | #15 | |
36/14 Overdrive = 2.57 38/13 Normal = 2.92 43/13 Underdrive = 3.31 Overdrive To Stock Difference= .35 Underdrive To Stock Difference= .39 Overdrive To Underdrive Difference= .74 | |
12-09-2011, 09:29 AM | #16 |
Quarry Creeper Join Date: Dec 2008 Location: La Costa, CA
I recently installed Underdrive in the rear of my Tundy and love it! So much so I bought a set for my Bronco. Climbs way way better. Didn't notice turning radius being better, but that was never a problem. I am running a 35T hand wound on 3S. If I was only using 2S I may have gone with just Overdrive in front. I heard there can be binding issues using both over/under but don't know for sure...
