12-10-2011, 08:31 PM | #1 |
Pebble Pounder Join Date: Mar 2010 Location: Stillwater
| ESC or Motor issue with my SCX
To make a long story short, I wired my Integy 55t motor to my Traxxas ESC, drove around the house perfectly. Took it outside and the ESC motor wires got wrapped around my front drive shaft to the point where it bogged down so bad it wouldn't barely go forward anymore. Since I had no idea this was happening I chalked it up to a dying battery and kept driving back to the house. After I got it inside I noticed the issue, I unwrapped everything and it hasn't ran right since. I'm assuming the giant load on the motor either fried the motor or ESC since I only have about 30% power going forward now, once it try's to climb anything moving forward it just stalls. Reverse is still strong with plenty of power. Any clue what it could be? I don't really have another motor or esc to test with.. |
12-11-2011, 12:30 AM | #2 | |
Quarry Creeper Join Date: Jul 2011 Location: Seattle
12-11-2011, 08:21 PM | #3 |
Well I swapped the wires soldered onto the motor and now I have the same weak power in forward or reverse, so I moved them back again. The controls are correct again, but the power is horrible. Full throttle on a steep hill and it just barely moves. Try to climb rocks with it and it falls on it's face, even with the slipper clutch backed way off. I put my battery in my wraith and it rips so it's not that. I'd love to get this combo, but cash it tight for my toys this time of year. Is there any way to test to see if the motor is good or if I fried that? I can swing a motor, the esc would be a hard one to slide by the wife. Holmes Hobbies LLC / Holmes Bikes :: Motors :: Brushed :: TorqueMaster Sport 540 Holmes Hobbies LLC / Holmes Bikes :: Motor Speed Controllers :: Holmes Hobbies TorqueMaster BR-XL |
12-11-2011, 08:41 PM | #4 |
RCC Addict Join Date: Jul 2011 Location: Orlando
Hell I have a motor I can send you. I know sometimes money is tight and its the Holiday I can do the hole "pay it forward" thing. At least you would know if its the motor or ESC. BTW, I have a AE-2 ESC ran once to test and then swapped out for a BR-XL if you would be interested just PM me. We can work something out but for now PM me your address and Ill get that motor out ASAP. |
12-11-2011, 08:42 PM | #5 |
Pebble Pounder Join Date: Apr 2010 Location: CSRA
Take a lower powered battery and just connect directly to your motor. Switch the wires and you will get the motor to move both directions. That should tell you if the motor is good. If you have a wraith, connect the wraith esc to your scx motor. Hope that helps. |
12-11-2011, 08:58 PM | #6 |
Rock Crawler Join Date: Sep 2011 Location: Southern Utah
If you have a wraith, start swapping parts (one at a time) and see which one fixes your problem |
12-11-2011, 09:16 PM | #7 |
Newbie Join Date: Mar 2009 Location: victoria
you could try replacing the brushes on the motor just incase and its only 2-3 bucks to do, hopefully its just as simple as something like that also this wouldnt have burnt out the slipper clutch or anything would it, im not really that familiar with the scx10s |
12-12-2011, 01:03 AM | #8 |
12-12-2011, 12:47 PM | #9 | |
Hopefully I've got a motor on the way to test with. From doing some internet recon, it sounds like I could have smoked the motor since it's now severely underpowered both forward and reverse. I appreciate all the help with this. I'm a 1:1 crawler so I frustrate myself daily with my lack of knowledge and the learning curve on these little ones. | |
