![]() | #1 |
Rock Stacker Join Date: Oct 2009 Location: Colorado
I have had my scx10 for a while now and I never noticed but, my steering angle sucks. I have a hard time making turns while out driving. Is this normal? Would anything short of high steer knuckles help? Such as a longer servo horn to effectively increase the "throw" of the steering? Is it just my servo? This is as far as it turns. Also, it turns further left than right, how come? Thanks guys! ![]() ![]() ![]() ![]() ![]() |
![]() | #2 |
Pebble Pounder Join Date: Mar 2011 Location: C.R.
What radio and servo are you using? Where is the steering EPA set?
![]() | #3 |
Ha ha, that might be part of my problem. My radio doesn't have adjustable epa.
![]() | #4 |
Quarry Creeper Join Date: Mar 2011 Location: Mn
I dont want to look like a smart aleck but is the bottom linkage hitting the axle housing before the c-hubs hit the axle? ![]() |
![]() | #5 | |
| ![]() Quote:
This is the servo I am using: https://www.ckrccrawlers.com/ckrc-sp...7579ef3ca360bb | |
![]() | #6 |
Well im not fantastic on electronics hopefully someone will chime in ![]() |
![]() | #7 |
RCC Addict Join Date: Aug 2010 Location: wherever paypal sais.
Step 1 set epa Step 2 make a longer drag link and connect to passenger knuckle. With that short drag link its causing serious bump steer Step 3 longer servo horn Step 4 this is the most important. Ensure ur servo is mounted securly.. looks like only 1 of the 2 available slots are holding it on. I'm willing to bet ur servo rocks side to side when you turn. And wedging ur esc in ther isn't exactly a good idea.. Step 5 3link w/ panhard.. that will eliminate all bump steer and that annoying only steers this much one way and that much the other. |
Maximize Steering Angle | CHRIZAD | Axial AX-10 Scorpion | 16 | 07-21-2009 11:24 PM |
Steering Angle | HiloDB1 | Kyosho Crawlers | 1 | 11-26-2008 12:05 PM |
steering angle limited | TRA3905 | Axial AX-10 Scorpion | 2 | 02-05-2008 09:50 PM |
Steering angle | NeoSlayer888 | Tamiya TLT Crawlers | 3 | 10-29-2005 08:21 PM |
