02-12-2012, 06:53 AM | #21 |
Rock Stacker Join Date: May 2011 Location: minnesota
| Re: MIP clearance issue? |
02-12-2012, 05:43 PM | #22 |
The ARTR AX-10 came without a slipper, the tranny tree has the plastic adapter plate to use that top shaft. I've stripped spurs but have not stripped the adapter. Not sure which top shaft to use with the Hot Racing plate.
02-12-2012, 08:16 PM | #23 |
Pebble Pounder Join Date: Feb 2011 Location: Knoxville
Mine came without a slipper as far as I know(second owner) and I am running the HR gear. --- I am here: http://maps.google.com/maps?ll=35.918263,-83.809517 |
04-18-2012, 04:43 AM | #24 |
Quarry Creeper Join Date: Feb 2012 Location: Canada
I ran into the same issue with my Dingo kit. Did you find a solution that worked?
04-18-2012, 10:57 AM | #25 |
Quarry Creeper Join Date: Apr 2012 Location: Marietta
I use the MIP shafts as well and it was a very close fit! I just decided that when it was rubbing it was not that severe so I just didnt pay any attention to it! Been that way for almost 6 months now and I have not had an issue yet!
04-18-2012, 11:21 AM | #26 |
| Re: MIP clearance issue? I've been running the Robinson racing 87 tooth and its a bit smaller diameter than the stocker.. Hope that helps. If not on the first page of this thread there is a link to a traxxas 84 tooth sour gear and that will week as well, plus give you a lil more wheel speed..
04-18-2012, 11:34 AM | #27 |
Pebble Pounder Join Date: Mar 2011 Location: St. Louis
Ditch the slipper. I am running the 89t with MIPs, no issues.
MIP clearance issue? - Similar Threads | ||||
Steering issue, axial high clearance knuckles | AgentXTC | Axial AX-10 Scorpion | 2 | 03-30-2013 09:34 PM |
Novak ballistic clearance issue | Mac28 | G-Made Crawlers | 8 | 03-20-2012 09:17 PM |
MIP CVD/ Spur gear clearance solutions? | Planespotter | Axial SCX-10 | 6 | 07-22-2010 02:35 AM |
MIP Driveshaft and Axial Slipper Clutch Clearance Issue | kawika | Axial AX-10 Scorpion | 8 | 06-30-2008 07:56 AM |
Steering arm clearance issue on Hi-lift | crawler_king | General Scale Talk | 1 | 01-09-2008 04:05 PM |
