02-16-2012, 07:58 AM | #1 |
Newbie Join Date: Nov 2011 Location: lakewood
| Shock questions i have a stock scx10 dingo tr and have been wanting to get some new shocks. i am looking at RC4WD Dual Spring 110mm Scale Black Shocks from RPP Hobby, i was wondering if these will work and if anybody has used them, i dont know the shock length of the orginals but i believe they are about 90mm. if these are not good can anyone recommend some good shocks that will increase performance, money is not an issue and i want some good shocks. also will longer shocks help articulation at all? thanks for any help guys its really help full. |
02-16-2012, 09:23 AM | #2 |
| Re: Shock questions
had them on a couple rigs and they were nice and scale looking and worked fairly well, but the O Ring inside would stick alot and had to change em out. plus the springs were to soft for my heavy trucks. maybe others will chime in.
02-16-2012, 09:27 AM | #3 |
| Re: Shock questions
could you use the springs from the orginal shocks to make them a little more stiff or are the springs differnt sizes, would you recommend them?
02-16-2012, 09:46 AM | #4 |
Rock Crawler Join Date: Jun 2010 Location: KCRC
| Re: Shock questions
The springs off a Losi MiniT will fit those shocks. They sell front and rear (they are different lengths) in a pack of 6, with three different spring rates in each. Play around till they work for your setup... fronts - LOSB1117 rears - LOSB1119 |
02-16-2012, 11:14 AM | #5 |
| Re: Shock questions What do you mean by the O ring sticking inside, i know what an oring is but did it cause the shock to not move or just leak? orwhat did the O ring do when stuck? |
Shock questions - Similar Threads | ||||
Shock Questions | EvoChaos | Axial SCX-10 | 13 | 05-11-2011 06:58 PM |
Shock Questions | Darrell262 | Axial XR10 | 9 | 10-18-2010 08:28 AM |
Shock questions | ballman6711 | Axial SCX-10 | 3 | 04-15-2009 05:51 PM |
Shock Questions | DiEzel | Losi Mini-Rock Crawler | 2 | 01-12-2009 11:34 AM |
Shock Questions | Trimmy | Axial AX-10 Scorpion | 2 | 01-25-2008 09:22 AM |
